Shadow Logger MS 1.02 Released
Re: Shadow Logger MS 1.02 Released
Post by LT401Vette »
If I switch to the firefly, I loose about 1 read/sec. I would be the rest is related to the Android 2.3, as both of mine are 2.2 and that is what I have tuned the timings to. I really should get a 2.3 device going here.
piledriver
Post by piledriver »
HTC Hero (CDMA/Sprint version) is a Oct 2009 vintage phone with pretty low specs by todays standards.
Single core 528MHz ARM11, Adreno 130 GPU, 288M RAM, 320 x 480 pixels, 3.2 inches (~180 ppi pixel density)
Takes up to a 32G class 10 microSD.
It was a "hot" phone when new. common as salt.
It shipped with Eclair, but is well supported by Cyanogen and other modders and is running Cyanogenmod 7.1//Android 2.37
I'm using a <$50 US converters BT-232 (class1) with internal antenna, i get ~11-12 hz with my 5+ year old laptop on MS2-3.20 Alpha.
Dongle is on the end of a 6' serial cable.
Range is well over 100 feet with the class1 dongle in my laptop, only tested it that far.
It's ~50 feet with the phone, but that's fine.
It makes for an excellent datalogger.
The Hero can also be had for $50-80 in working shape, but the USB ports are a lame design.
I would only cry for the microSD if I lost it/dropped it etc.
piledriver
Strangely, it was doing 10-12 hz logs this morning when I looked.
I have no idea what changed.
That's much better.
angus99
Post by angus99 »
Just found this via google. Parrot Asteroid Android powered car radio. Any ideas if the will run shodow logger?
http://www.parrot.com/uk/products/hands ... t-asteroid
angus99 wrote:Just found this via google. Parrot Asteroid Android powered car radio. Any ideas if the will run shodow logger?
That looks pretty cool, but it is hard to tell. They don't say what version of Android is on it, or if you can install your own apps.
If it is Android 2.1 or higher, has Bluetooth and lets you install your own apps, it should work.
ChevytoyR1
Post by ChevytoyR1 »
Phil i got ur bluetooth today and tried it out on my boostmobile samsung prevail and works great..
my only question is can u change the rpm readout on the screen to something else? i would like to switch to coolant, lambda, rpm on the phone screen? i have android 2.1
You can't change them in this release, but a real dash is coming.
ChevytoyR1
ahh ok.. nice :yeah!: .. hey what are the cables on the bluetooth for anyway? lol or where can i read some instructions on it?
turbo355
Post by turbo355 »
I have mine running on a Samsung Captivate 3g phone with a ebay bluetooth to serial.
11.1 +/- .3 on MS3 1.0.3
10.4 +/- .4 on MS3 alpha16
14.0 +/- .6 on MS3 3.0.3v
Seems to work very well so far.
2000 Suzuki Hayabusa turbo MS3 beta testing Plug and Play standalone
http://interfacepnp.webs.com/
http://www.youtube.com/Busams
rx7_ben
Post by rx7_ben »
Hi guys,
I have set up my Bluetooth adaptor and it seems to be working well. I did my first test datalog which has saved as an FRD file. I attempted to convert it using tunerstudio 1.20 beta, but it is saying the signatures do not match. My project signature is "MSExtra Rel 2.1.0p" and it is saying the FRD file is "MS2". The firmware on the Megasquirt 2 is 2.1.0p and matches the TS project just fine, is there a reason why this is happening and what can I do to resolve it. I'm a bit lost.
Cheers,
Ben.
PS. I can't wait for full dashboard and tuning interface on droid :)
There are 2 ways to convert the FRD into a normal msl.
1) Let Shadow Logger Upload it to ShadowTuner.com: ShadowTuner.com will convert it to a normal msl log file. You will need to upload an msq from your PC too.
2) TunerStudio can transform it as well. From the main menu:
Data Logging --> "Import / Conversion" --> "Convert Binary Log (MS3, FRD)"
That will turn it into a normal log also...
One important note. If you are logging Accelerometer Fields, you must use either ShadowTuner.com or the beta TunerStudio 1.18 or higher. TunerStudio 1.004 does not know how to handle those.
rx7_ben
Post by rx7_ben »
Thanks Phil, I amended my post just as you made your post sorry. I worked out how to convert the log, but I am experiencing the difficulties as above. I'm not logging accelerometer data at this stage. Keeping it plain and simple for now. Although I did try to upload an msq from my pc to shadowtuner.com and it tells me I have insufficient access rights.
Hmm... I think I see the problem. Give that another try.
rx7_ben
Post by rx7_ben »
Thanks Phil,
I am able to upload my .msq now but it doesn't seem to want to let me upload my ini (Ecu definition). While I'm not entirely sure which file this is (I think it's megasquirt-ii.ini but I'm not sure), it doesn't seem to accept anything I throw at it. Also, I'm not able to download my logs from shadowtuner.com. It says that I do not have read access to to projectid:
Also, is there a way to get around the "MS2" signature issue I'm having with the log? I've got a feeling shadowtuner.com might be having the same difficulties interpreting/converting the log as TunerStudio based on the signature mismatch.
What firmware are you using?
Most of the common ini files should already be on the server.
rx7_ben
Post by rx7_ben »
I'm using 2.1.0p on ms2
Perhaps a screenshot / photo of the error messages you are seeing might help clarify things somewhat.
rx7_ben
Post by rx7_ben »
Sure thing.
This is the error I receive when trying to convert the FRD log file using tunerstudio beta 1.20
This is what the project setup page looks like on shadowtuner.com. It says the definition file cannot be found.
Does that help clarify? Let me know if there is any other scraps of information that will help.
Yes... It looks like that FRD does not have a complete signature. It seems to be truncated.
When you connect with Shadow Logger, does the displayed signature seem complete? Is it sometimes truncated?
Try to capture a new Log File.
