MS2
V3.0PCB
any body got any advice?
much appreciated
jsmcortina wrote:Is there a dot? That indicates pin 1.
Also if you look at the chip with the writing the correct way up, pin 1 should be bottom left.
lukej wrote:onto other issues... ive gone and soldered U4 where U7 should go![]()
taking it real slow steady with the heat trying to use the solder sucker on it
Return to Board assembly and testing
Users browsing this forum: boofhead and 1 guest
