U3 6pin chip orientation
Postby lukej » Thu Dec 22, 2011 9:31 am
Hi I need a bit of help with the orienation of U3, theres no notch on the chip to correspond with the notch on the board,
MS2
V3.0PCB
any body got any advice?
much appreciated :)
lukej
Re: U3 6pin chip orientation
Postby jsmcortina » Thu Dec 22, 2011 9:35 am
Is there a dot? That indicates pin 1.
Also if you look at the chip with the writing the correct way up, pin 1 should be bottom left.
Postby lukej » Thu Dec 22, 2011 9:40 am
ok so the dot goes the same end as the notch or the dot goes the opposite end?
got another major issue....
let me sort U3 out first though!!!
lukej
Postby lukej » Thu Dec 22, 2011 9:46 am
jsmcortina wrote:Is there a dot? That indicates pin 1.
thankyou James, ive found clarification on the pcb layout http://www.msextra.com/doc/ms2extra/MS2 ... htm#layout
onto other issues... ive gone and soldered U4 where U7 should go :oops: :| :| :|
taking it real slow steady with the heat trying to use the solder sucker on it
lukej
Postby kjones6039 » Thu Dec 22, 2011 3:03 pm
lukej wrote:onto other issues... ive gone and soldered U4 where U7 should go :oops: :| :| :|
Another good reason to install sockets, IMHO.
383 CID SBC w/ Holley Pro-Jection 900 CFM TBI, 4-85 lb lo-z injectors & Walbro 255 pump
MS2 v3 w/Firmware? Depends on the phase of the moon. Currently-ms2extra_pre3.3alpha5_gslender_v2.8a
Wasted spark, 36-1 wheel, Ford coils, 4 coil driver board from JBPerformance
SLC OEM WB from 14point7
kjones6039
Postby lukej » Fri Dec 23, 2011 8:32 am
yeah maybe... hindsight and all that :(
lukej
Return to Board assembly and testing
Users browsing this forum: Bing [Bot] and 0 guests
