1.04 to 1.19 question
I would like to try 1.19. Current: MS2 Extra 3.1.1 TS 1.04. I went to your site and downloaded the 1.19 and it created another TS with icon. Do I load my current tune then power off and then bring the controller on line. Thanks, David
Re: 1.04 to 1.19 question
That will work, but I would create a new project in 1.19 and load my current tune to that project. That way your tune will also be saved if you want to go back to 1.04......turbo conversion wrote:I would like to try 1.19. Current: MS2 Extra 3.1.1 TS 1.04. I went to your site and downloaded the 1.19 and it created another TS with icon. Do I load my current tune then power off and then bring the controller on line. Thanks, David
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Thank you Ken, that is what I will do. Also, how do you get my post to apear in your response? David
By clicking the "QUOTE" button at the top right of your post.turbo conversion wrote:Thank you Ken, that is what I will do. Also, how do you get my post to apear in your response? David
