Philip Lochner wrote:I build ALL my MS's with real time barometric sensors having found how important it is to correct fuelling for barometric changes.
dontz125 wrote:I would wager that a 2x2 chart (adder deg vs Baro kPa; 0 @ 85, -3 @ 100, to use Philip's example above) would solve most of the problem. I'd be surprised if a 6x6 chart was needed.
gslender wrote:As I'm currently away from home and bound to an iPad, and unable to launch TS, can you outline for me which sensor input the 2nd baro map sensor uses... As the MS2 is fairly limited in the number of inputs, just curious what it consumes to get that 2nd sensor reading in....![]()
pigga wrote:Hi Philip - just out of curiosity: What's the Octane number of the fuel available at your location?
Thomas
hassmaschine wrote:doesn't % baro already do this for you? is your timing map 100% flat or something?
