1.19 question
1.19 question
Postby turbo conversion » Wed Dec 28, 2011 6:38 pm
Is TS 1.04 required to run 1.19 or can you run 1.19 without 1.04 installed? Thanks, David
turbo conversion
Re: 1.19 question
Postby 93white3400z » Wed Dec 28, 2011 6:39 pm
It's not required.
MSDroid (Android App) for MegaSquirt available for free!
Like MSDroid on Facebook
1993 Chevrolet Cavalier Z24
3400 Turbocharged Intercooled
MS3 v3.57+MS3X
93white3400z
Re: 1.19 question
Postby jsmcortina » Wed Dec 28, 2011 6:39 pm
Agreed, they are independent.
For reference, all MS2/Extra and MS2/Extra variants work on 1.004
MS3 1.0 versions work on 1.004
MS3 1.1 alpha test versions only require 1.19 (or the latest beta)
Re: 1.19 question
Postby turbo conversion » Wed Dec 28, 2011 6:44 pm
Thanks for the quick response guys. Thought this could be some of my problem. Still going with the new computer solution.
David
turbo conversion
Re: 1.19 question
Postby jsmcortina » Wed Dec 28, 2011 6:46 pm
What problem?
Re: 1.19 question
Postby turbo conversion » Wed Dec 28, 2011 6:52 pm
The issue with fan and iac settings disapearingafter loading 3.2.1 and TS1.19 David
turbo conversion
Re: 1.19 question
Postby jsmcortina » Wed Dec 28, 2011 7:02 pm
turbo conversion wrote:The issue with fan and iac settings disapearingafter loading 3.2.1 and TS1.19 David
I'd say those are unrelated to TS or your tuning computer. They are a settings problem.
Re: 1.19 question
Postby turbo conversion » Thu Dec 29, 2011 6:43 pm
Hi James, I had the day off so I talked with Matt at DIY. I sent him my msq and all I needed to do was disable fidle. In my post I did not say I am using PWM Closed Loop so fidle was set up as on-off. Thanks for your response, David
turbo conversion
Return to Tuner Studio
Users browsing this forum: Bing [Bot], Trev16v and 2 guests
