1.19 question
1.19 question
Is TS 1.04 required to run 1.19 or can you run 1.19 without 1.04 installed? Thanks, David
Re: 1.19 question
It's not required.
1993 Chevrolet Cavalier Z24
3400 Turbocharged Inter-cooled
MS3 v3.57+MS3X
MS3 v3.57+MS3X
Re: 1.19 question
Agreed, they are independent.
For reference, all MS2/Extra and MS2/Extra variants work on 1.004
MS3 1.0 versions work on 1.004
MS3 1.1 alpha test versions only require 1.19 (or the latest beta)
Re: 1.19 question
Thanks for the quick response guys. Thought this could be some of my problem. Still going with the new computer solution.
David
David
Re: 1.19 question
What problem?
Re: 1.19 question
The issue with fan and iac settings disapearingafter loading 3.2.1 and TS1.19 David
Re: 1.19 question
I'd say those are unrelated to TS or your tuning computer. They are a settings problem.turbo conversion wrote:The issue with fan and iac settings disapearingafter loading 3.2.1 and TS1.19 David
Re: 1.19 question
Hi James, I had the day off so I talked with Matt at DIY. I sent him my msq and all I needed to do was disable fidle. In my post I did not say I am using PWM Closed Loop so fidle was set up as on-off. Thanks for your response, David
