Or type a device path (default: /dev/ttyS0): /dev/tty.usbserial
Scanning serial device: /dev/tty.usbserial ..
WARNING!!!
No valid ports or ECUs found. Cannot load firmware without communications.
shauer wrote:Any insight into my problem descrtibed above with the BlueTooth communications with the Windows loader?
The Windows loader did not like COM40 for a serial port.
What happens when you manually type in 40 as the COM port ?
Please post a snippet of the output with debug level 3 enabled.
