djp0623 wrote:What are typical values for that type of idle advance table. I'm not really sure where to begin. My idle is pretty stable as is. What advance increments is typical for -100, -200, etc?
krisr wrote:*) The new boot loader .exe did not work, would not detect the com port (USB-RS232 dongle). The old firmware loader worked fine - wasn't sure if I needed to do anything to the MS3 before flashing?
*) My apacer 2GB SD card is now showing error 5 (unsupported card), but was working on 1.0.5 beta.
Zaphod wrote:@James/Ken: Didn't you want to add the alternator control to alpha 18? What happend to that?
Thanks!
jsmcortina wrote:What messages do you see? Could you try the new loader again with debug level 3 ? (You can cancel it before it reloads the firmware.)
This is most odd, while I've changed lots of small things in the SDcard code, I thought that the initial setup code was identical to 1.0.5.
What SDcard SPI baud rate do you have set.
krisr wrote:jsmcortina wrote:What messages do you see? Could you try the new loader again with debug level 3 ? (You can cancel it before it reloads the firmware.)
Will be able to verify tonight - will report back.This is most odd, while I've changed lots of small things in the SDcard code, I thought that the initial setup code was identical to 1.0.5.
Are you referring to the "SPI Comms Speed" in the SD Card Datalogging menu? If so, that's set to "Normal". Will try other speeds tonight.
Keithg wrote:Oh, yeah, I think I saw the same deal I was seeing before where if it started and did not 'rev up' I would have to stab the accelerator to prod it into CL idle right after startup. It is warm now (both the engine and the ambient), so I will have to check it tomorrow to see if it still does this on a cold start...
Keith
franksidebike wrote:what is Auto-zero-TPS in the General setings?
franksidebike wrote:Hi Guys
Littel update:
new downloader no problems!
i love the new deccel, more steps!
in the ms2extra_3.2.1_gslender_v2.2c is a Median Sliding Window, in ms3-pre1.1alpha18 no?
jsmcortina wrote:If on startup your TPS is showing a negative number the feature resets that to zero. This can be useful if you get slighlty varying TPS values. Calibrate with the lowest number you see and this feature should held mean that 0.0 is closed.
