I am running MS1 V3 in Alpha-N on my car.
The system is working fine, the map is as good as I can get it and i`m happy with it.
However, there are a couple of RPM points on the MAP that aren`t where I want them to be. As the MS1 has limited resolution, I want to move the RPM points on both the fuelling and spark tables.
Is there an excel sheet or similar that someone has created that lets me put in my current table, then on a `target` table, I can change the RPM points and it calculates the necessary fuelling values using the same calculation as Megasquirt.
I have a couple of small AFR dips that can be seen to change as the fuelling goes into the next cell, I`m wanting to try and tune this out, but need to increase resolution in those areas at the expense of more stable zones.
Obviously, I could do it by trial and error, but if there is a method of automating the calculating of the desired target values, that would obviously be my first choice.
Nige.
