I have also run in to the same problem as "16vboost" that the AFR jumps lean when in overrun area even when overrun cut turned off. As I too now started to tune my EAE curves.
As you can see in the log capture the AFR behaves as the overrun fuel cut would be on even when it's not.
It might be because PW gets too low to 1.2ms and at idling it is 1.7ms. Injector dead time is 0.55ms calculated with flow testing "Deka 630cc"
- log_ve_table.bmp (640.54 KiB) Viewed 475 times
But will this affect my EAE tuning?
I will use overruncut anyway when I'm done with the EAE curves.
And another question to the EAE tuning, perhaps a silly one.
There are instruction on how to tune the EAE. Keeping the rpm steady and chaning the kpa example from 40 to 80 and change the curve EAE curves depending on the result. But whitch point of the curve, the 40 kpa point or the 80 kpa or something else?
Thank you.
