MS2/extra alpha 3.3.0a (2012/02/05)
Changes since 3.2:
- Incorporated gslender's backports of ms3 idle features. Some are direct backports and some are re-implementations where necessary given ms2's limited resources
- Changed 100 to 100L to prevent EgoLimit multiplication overflow
- Make rotary trailing work with 36-2-2-2 wheel
The firmware can be found here:
http://www.msextra.com/doc/ms2extra/fil ... 120205.zip
Re: MS2/extra alpha 3.3.0a (2012/02/05)
Thanks Ken! Was anything changed in the smoothing/filtering of the inputs (map,RPM,tps, etc)?
1996 Mazda MX-5 1.6L NA6/ Mazdaspeed M45 SC/ BSP AW Intercooler/ Maruha F-cams/ 425cc RX-8 injectors/ DIYPNP
MS2/Extra test mule
MS2/Extra test mule
That has not yet been backported from MS3. It will at some point be backported.
Hi,did the rotary mode un microsquirt mode is fixed in this alpha?
Frank Racing,Naranjito Puerto Rico,installations and tuning solutions
FrankRacing.Naranjito@gmail.com
I have not been able to reproduce your issue.
ok, I will rewire and try it with this alpha thanks Ken
Kudos!
6/1 wheel sequential, Bosch CIS air valve ONLY for start/warmup fast idle .
The new idle control ROCKS for me, as I only use timing control for active idle stabilization.
I used to use the transition from cold idle+table timing to idle control as an audio cue I was warmed up as it started hunting up/down when it hit setpoint. (was still +/- ~75 RPM, better when warmed up)
Now idle speed and recovery is smooth and rock steady.
All I had to do was turn it back on and set it to adaptive, and it works ~like a PID closed loop idle speed control, without having to jack with it. (have not had a chance to play with it properly)
I was planning on finally getting around to installing an idle air valve, but now I may use fidle for something else.
No issues noted, ~150 miles so far on this code.
I tested again and the problem persists even if set it to 6 cylinder and 8 waste spark it do not fire I used a v2 microsquirt and a v3 as well... If you can get it to work please post the msq and the wiring setup , thanks!!muythaibxr wrote:I have not been able to reproduce your issue.
Post your MSQ.chango de naranjito wrote:I tested again and the problem persists even if set it to 6 cylinder and 8 waste spark it do not fire I used a v2 microsquirt and a v3 as well... If you can get it to work please post the msq and the wiring setup , thanks!!muythaibxr wrote:I have not been able to reproduce your issue.
sorry forgot to post the msq...jsmcortina wrote:Post your MSQ.chango de naranjito wrote:I tested again and the problem persists even if set it to 6 cylinder and 8 waste spark it do not fire I used a v2 microsquirt and a v3 as well... If you can get it to work please post the msq and the wiring setup , thanks!!muythaibxr wrote:I have not been able to reproduce your issue.
Rotary isn't enabled in that MSQ??
No fault found.
I've tested 6cyl w/s, 8cyl w/s and 4cyl with rotary enabled.
I did find a mistake in your MSQ though - you have spark output set to "normal" when it should be set to "inverted"
Oh,I did that to see if had any change but the only change was me burning the coils,please post the wiring you use maybe was me wiring it wrong, thanks!!jsmcortina wrote:No fault found.
My wiring was:
Microsquirt module -> LED on Jimstim.
Having the dwell set upside down will smoke non self-protecting coils, as will shorted tab> insulators>case on the drivers.chango de naranjito wrote:Oh,I did that to see if had any change but the only change was me burning the coils,please post the wiring you use maybe was me wiring it wrong, thanks!!jsmcortina wrote:No fault found.
did you use pull ups? and the rpm input of the stim?jsmcortina wrote:My wiring was:
The module spkC and spkD will need pullups to 5V yes.
Perhaps it would help if you posted a full description of what problems you are having. All I've gather so far is "it doesn't work" but I have no idea what test situation you are using, wiring or anything.
I will try again and post the full information and a video if I can, sorry for the lack of infojsmcortina wrote:The module spkC and spkD will need pullups to 5V yes.
I looked in the changelog but it must not be updated yet. What new idle control is in this version? Will it work for fuel only applications?piledriver wrote:The new idle control ROCKS for me.
I'm currently using the ignition control, it twiddles the ignition timing for idle stability.tomeric914 wrote:I looked in the changelog but it must not be updated yet. What new idle control is in this version? Will it work for fuel only applications?piledriver wrote:The new idle control ROCKS for me.
I'm using glsenders variant currently, can't recall if the idle timing mod was now in mainline.
