Issue on single dizzy odd fire engines (patch included)
(Runs on MS2 and Microsquirt)
Postby karlo » Tue Feb 07, 2012 3:49 pm
We discovered an issue with single distributor odd fire engines. Specifically, this is a 90 degree odd fire V6. The code doesn't shorten dwell correctly at high rpms, causing dwell for two separate ignition events to overlap. This obviously causes an entire bank to drop out, in addition to overdwelling the coil. I attached some images to illustrate the problem. The following are the ignition settings:
Ignition settings
Scoping the ignition output at 4500 rpms shows the spark output getting pulled down correctly and working just fine (potentially too short spark duration here, though):
Ignition working
Scoping at 5300 rpms shows the overdwell and complete lack of spark for the one bank:
Ignition failing
The following is a fix for this issue. The code for odd fire distributor mode gets this right, but the code is valid for any odd fire engine with a single coil:
Code: Select all
diff -uri orig/ms2extra_3.2.1_beta/ms2extra/ms2_extra_main.c ms2extra_3.2.1_beta/ms2extra/ms2_extra_main.c
--- orig/ms2extra_3.2.1_beta/ms2extra/ms2_extra_main.c  2011-12-08 16:04:05.000000000 +0100
+++ ms2extra_3.2.1_beta/ms2extra/ms2_extra_main.c       2012-02-07 19:53:53.756230800 +0100
@@ -3276,7 +3276,7 @@
                         /* rotary or DLI force 1 */
                         max_dwl_time = dtpred_local;
                     } else if (flash4.ICIgnOption & 0x8) {
-                        if (spkmode == 2) {
+                        if (num_spk == 1) {
                          // in odd fire set max dwell for shorter period
                             if (dtpred_last_local < dtpred_local) {
                                 max_dwl_time = dtpred_last_local;
Mind you, running a single distributor on a V6 90 degree odd fire engine is basically the same as on a even fire V8. The dwell time at 6500 RPM is < 2.3ms, so I'm not sure it's a great idea. However, a friend ran into this issue, so I put together this fix for him. The code hasn't been tested on the car yet, only scoped the outputs.
- Karl
karlo
Re: Issue on single dizzy odd fire engines (patch included)
Postby jsmcortina » Tue Feb 07, 2012 3:53 pm
Thanks for the patch.
What code is this against?
Postby karlo » Wed Feb 08, 2012 6:26 am
It's against ms2extra 3.2.1.
Thanks for the attention!
- Karl
karlo
Postby jsmcortina » Wed Feb 08, 2012 6:35 am
karlo wrote:It's against ms2extra 3.2.1.
OK, good.
I'll add it to the TODO list. Any change like this requires a lot of testing in case the are unexpected side-effects in the many other modes.
Postby sunfield » Mon Apr 02, 2012 12:16 pm
Hello James,
I understand this issue will put on your todo list.
When do think this solution will be integrated in a release?
I am interessed in this fix, because I have an odd-fire engine.
Regards
Otto
sunfield
Postby jsmcortina » Mon Apr 09, 2012 5:16 pm
This issue had slipped off the radar. I'll be looking at it in the next few days.
Postby jsmcortina » Tue Apr 10, 2012 5:31 am
Karlo's fix looks fine. I've tested it on the bench and don't see why it should cause a problem. It is added ready for 3.2.2 which should be soon.
Postby ScoobyCoder » Mon Jun 25, 2012 9:43 am
James,
To confirm 3.2.2 or above has this issue fixed and can be used on our oddfire engine (which was losing power above around 4k, which I think was exactly this bug... :)
Mark
ScoobyCoder
Postby jsmcortina » Mon Jun 25, 2012 11:58 am
Is that a question or a confirmation that the fix works?
Postby ScoobyCoder » Mon Jun 25, 2012 1:31 pm
james,
Was a question, but you answered via PM. I will check tomorrow if it works and report results after we get booked on the rollers towards the end of the week.
Thank you,
Mark
ScoobyCoder
Users browsing this forum: trevi and 0 guests
