I just built a DIYPNP for my turbo 93 accord f22a6. In the setup page for the honda http://www.diyautotune.com/diypnp/apps/ ... z6-mt.html it has me hook up inj1 and inj2 to the ecu connector. Does this mean I need to use Bank2 under injector characteristics?
Thanks in advance for any help
Cory
Do I need to use Injector Bank2 in TS
Re: Do I need to use Injector Bank2 in TS
Only if you have a different type of injector connected to bank 2.
That's why it is called "Different bank 2 setting"
James:
Thanks for the quick reply. New to megasquirt here and just wanted to make sure. I hope to do a writeup on my accord when Im done so others dont have to do all the same work Ive had to.
Thanks again
Cory.
Thanks again
Cory.
What would this be used for?
Ms2-3.4.2 v3.0 .
Turbo BMW m30b35.
Turbo BMW m30b35.
As I wrote here.
jsmcortina wrote:Only if you have a different type of injector connected to bank 2.
So on a 6cyl
3 injectors are 42# and the other 3 could be 60#?
Just curious who would use something like that or what it's for.
Ms2-3.4.2 v3.0 .
Turbo BMW m30b35.
Turbo BMW m30b35.
A setup like this would be used in a staged injection arrangement; the smaller injectors would usually be the "low-speed" set, with the larger set adding in somewhere closer to WFO.
