no fuel pump action?
Postby stu » Thu Mar 01, 2012 12:26 pm
hey all... i have managed to get my TR6 running with the MS1 using megatune 2.25... cranks over, starts, runs...etc... but now all of a sudden... no fuel pump relay action... not even the key-on prime for 2 seconds.. i plugged in my megastim v2 (old one) and confirmed it... no fuel pump LED coming on. please tell me i just did something silly and obvious.. :-)
thanks.
stu
Re: no fuel pump action?
Postby Matt Cramer » Thu Mar 01, 2012 2:42 pm
Sorry - if reloading the firmware and loading a map from before the problem doesn't fix it, it's probably a blown fuel pump output transistor.
Postby stu » Thu Mar 01, 2012 3:16 pm
thanks for the reply! i'll reload an old map... see what happens... if no luck i'll pop in a new transistor. any idea how a transistor would just up and die? it is used only for controlling the relay, right?
-stu
stu
Postby kjones6039 » Thu Mar 01, 2012 4:07 pm
Please disregard.... wrong topic.... :oops:
MS2 v3 w/extra 3.4.2 Release
kjones6039
Postby Matt Cramer » Fri Mar 02, 2012 6:47 am
Could have been a bad transistor, a bad solder joint, or too much current.
Return to MS1/Extra support
