Running 3.06
I am Logging MS3 and am NOT running sequential injection currently. When set to Auto detect, I get errors on instantMPG as well as other calcs because ML appears to be assuming I am running sequential injection. Tried manually setting field ECu definitions to Megasquirt, but that throws and GEGO error when trying to load VE analyze (I am assuming because they are not MS3 defs). Thoughts?
Also, The instant MPG calcs do not appear to be taking into consideration Fuel Cut. I guess I could add a range limit. Thoughts? I can post a log if necessary.
Thanks,
Shawn
