durson1 wrote:I will try those changes. Idle was always rich, 12-12.5 afr.
The setup I was following was the directions from "elaw" in this post.
http://www.msextra.com/forums/viewtopic ... 01&t=40570
I wanted to use VEAL to help fine tune once I got a working maffactor file.
durson1 wrote:I think I just need a better starting point. What MAF sensors do you have curvesw for? I am willing to change it out to get this to work.
[OutputChannels]
voltsADC7 = {adc7*0.0048876}
voltsADC6 = {adc6*0.0048876}
[Datalog]
entry = maf, "MAF", float, "%.3f"
entry = mafmap, "MAFMAP", float, "%.3f"
entry = adc7, "adc7", int, "%d"
entry = adc6, "adc6", int, "%d"
entry = voltsADC7, "MAFvolts", float, "%.3f"
entry = voltsADC6, "Knockvolts", float, "%.3f"
durson1 wrote:Soif I do change maf sensors do you have a curve for that n60? Is that off a maxima?
durson1 wrote:I spent more time reading your writeup. Let me see if I get this. After I add that custom.ini, while running on my SD tune, I log :
ADC count, and MAF volts. And I do that with my best estimate mafanalyzer file burned? Or does that not matter? And is this just to see if my MAF sensor is correctly sized?
I think I then understand the tuning side. Towards the end of the document when you speak of percent changes if your rich or lean after you calculate you do that in the maf correction table, then make it a permanent change with new numbers in the mafanalyzer program. Correct?
Maybe I am missing something. And this needs to be done with ego correction off?
My files I've generated with mafanalyzer haven't been close at all. I couldn't even get out of my driverway with ego correction on. Or is that file generated using info gathered from datalogging with my SD tune. I am missing something. and talking in circles I think.
