frank_ster wrote: i have pretty much unlimited resources. what can i do to make this happen ?
frank_ster wrote:from reading the injectors are about 60 volts and 1.5 amps. so about 100 watt. but also 100 watt for what half milisecond ? then lower to hold position. and then realease. the overall duty cycle would be about 2% but even 10 amps at 100 volts would be a 1000 watts at 2% duty cycle so 1000 watts divided by 50 would b e about 20 watt average. so i;m sure an array of capisitors would making things happy.
thanks for the input, i will also draw up a sketch as you say, see what looks nicer!
frank_ster wrote:piezo,
from my understanding they open with a peak then hold, and then reverse to "push" closed,
but the total injection length would be about 5 ms at high loads. and probably 500 ns or less at idle.
so they are high current but for a very short amount of time. since the start and finish of the fire needs to be with in a few degrees of tdc.
Users browsing this forum: Google [Bot] and 2 guests
