Sellig78 wrote:Ok so i just put 0 in the load threshold and the idle advance strategy doesn't care if the engine load goes under.
Thinks guys!
I got it to work on the stim for a very narrow range of throttle inputs but only if I improperly calibrated the TPS to allow negative values.Sellig78 wrote:I agree with you Peter i still don't have success with the idle advance strategy with alpha-N, even with the load threshold at 0.
gslender wrote:In the later code releases I added an option for idle advance to enable when it goes into CL-Idle....and this options ignores all the other conditions and uses the same condition the idle code uses (which isn't load based etc).
Also, you get the adaptive advance based on rpm target which I believe is much superior.
Try that hey?
G
Peter Florance wrote:gslender wrote:In the later code releases I added an option for idle advance to enable when it goes into CL-Idle....and this options ignores all the other conditions and uses the same condition the idle code uses (which isn't load based etc).
Try that hey?
G
Sounds like a plan.
Does it matter that the car has no idle valve?
gslender wrote:Peter Florance wrote:gslender wrote:In the later code releases I added an option for idle advance to enable when it goes into CL-Idle....and this options ignores all the other conditions and uses the same condition the idle code uses (which isn't load based etc).
Try that hey?
G
Sounds like a plan.
Well kinda as it relies on the CL-idle code running, so you do have to configure it so etc. not sure what that means really as its point is to control the idle valve and if none exist it will be just trying to control nothing.
G
Peter Florance wrote:I'll leave a bucket to collect all the unused PWM....
gslender wrote:Peter Florance wrote:I'll leave a bucket to collect all the unused PWM....
Actually, you only need an drain tube directly to the road. The ms2 makes pwm freely and doesn't need to be topped up or replenished
