newb db9 to usb leads question - UK
Click here to enter
Contact a Forum Administrator
Postby jjmclure » Wed Mar 14, 2012 2:24 pm
Hi there, I am looking for a db9 to usb cable and have seen some real cheapy jobbies on fleabay. Are these ok to use with a MSII?
Example:
http://www.ebay.co.uk/itm/USB-2-0-RS232 ... 415f24138d
jjmclure
Re: newb db9 to usb leads question - UK
Postby billyjarrell » Thu Mar 22, 2012 8:02 am
We have seen some USB to DB9 adapters that do work and some that don't. I would recommend this one:
http://www.diyautotune.com/catalog/usb- ... -p-67.html
Haven't seen any issues out of this adapter. Although do make sure to plug the adapter directly to your tuning PC and run the serial cable from the MS to it.
We have had some noise interference issues when used the other way around.
billyjarrell
Postby jsmcortina » Fri Mar 23, 2012 4:26 am
The USB-serial cable I use came from Maplin. It is based on the Prolific chipset and works for me on Windows XP and Linux.
Postby James » Fri Mar 23, 2012 5:03 am
I'd recommend one based on an FTDI chipset - I've had the most luck with one of those.
Triumph 2000 Mk1 — 2 litre straight 6 — MS3+MS3X, 36-1, wasted spark — Install Details
Triumph Spitfire Mk3 — clockwork
Twitter
Postby jjmclure » Sat Mar 24, 2012 1:53 pm
sorry what's an ftdi chipset?!
jjmclure
Postby SymTech Laboratories » Sat Mar 24, 2012 2:53 pm
jjmclure wrote:sorry what's an ftdi chipset?!
While there are many USB-serial cable manufacturers, there aren't nearly as many USB-serial chip manufacturers. FTDI and Prolific are two of the most common chip manufacturers, so most cables use either an FTDI or Prolific chip. For instance, the cables we sell use the Prolific chip. IOGEAR cables also use the Prolific chip, whereas Sabrent cables use the FTDI chip. This information should be available from the cable manufacturer or vendor.
SymTech Laboratories, LLC ----- MSQ File Repository: megasquirt.symtechlabs.com
Postby jjmclure » Tue Apr 03, 2012 2:29 am
Thanks for your help guys!
jjmclure
Users browsing this forum: Yahoo [Bot] and 2 guests
