wrenchdad wrote:James,
I know you and Ken are shooting for a release soon of 1.1 but I was wondering if I could request a feature, if not on this version that maybe on the list for the next, 1.2?
Here is my issue, when running AC, which down here in the south is just about all times, and when pulling from a stop, the load of the AC makes it like a night and day difference compared to when its off, stalls at times unless feather the clutch and sometimes I miss it. SO...........
I was thinking if there was a cutout for AC that was tied to rate of change of TPS , that would allow the dropout of this high load even when I am below my normal TPS cutout of 40%. Just not a lot of torque on these little 1.6 motors. Or maybe a low rpm cutout that would drop this load to help prevent stalls?
thanks
wd
Are you opening up your idle valve with the A/C on? i.e. do you have an RPM added to nominal idle RPM? Ideally you'd have enough extra idle speed that the extra load from the A/C is accoutned for by the idle valve during takeoff. Normally (at least in my logs), the idle valve doesn't close instantly, but rather over time after exceeding the minimum TPS threshold.
jsmcortina wrote:The current TODO before we complete 1.1 stands as follows:
Wheel decoders:
- GM7X - review / test sequential cam support
jsmcortina wrote:Feature enhancement:
- When closed loop idle is enabled, make Idle Timing RPM correction optionally
depend on that instead of the normal conditions for coming on.
- Prime pulse delay
Wheel decoders:
- Chrysler 2.2/2.5 continue refinements to make it sync more quickly
There are some incomplete wheel decoders which may be removed before release.
- 36-2-2-2 V6 application - waiting on data
- Viper V10 wheel mode - untested
- Audi flywheel mode - seems tricky to get right
- Nissan CAS - do they all work?
- Optispark mode - reliable or not?
- NGC 6cyl cam sync - waiting on phasing data
jsmcortina wrote:There are some incomplete wheel decoders which may be removed before release.
Zero feedback received.
