LT401Vette wrote:So they are bouncing around on the Gauge, but the log file looks right...
What Dashboard are you using?
1 Errors:
Error: Malformed [OutputChannel] entry, Problem at:
[./inc/lambdaSensors.ini]:[Line:85]: TargetAFR = { table( afrtarget*5/255 ,"zeitronix.inc") }
I installed the beta version of TS and AFRs meter looks normal now! It may have a difference of a ~0.3 but.. who cares.. No irrutional reading or bouncing all over.
The bad news is that although i dataloged for about 10 minutes with Beta TS, when i open the .msl file it has no records..
LT401Vette wrote:I installed the beta version of TS and AFRs meter looks normal now! It may have a difference of a ~0.3 but.. who cares.. No irrutional reading or bouncing all over.
Are you sure it has no records? Check the File size. I think this might be related to an issue where the beta TS makes the 1st record a MARK if you started the data log before going online, then MLV can't handle that. I will have an updated MLV out later today that fixes this.
LT401Vette wrote:Ok, that log file is fine, but the beta TS writes units to the log file. A MegaLogViewer that old probably doesn't know how to handle them, that started at around 2.99.
It opened fine with MegaLogViewer 3.02. You need to upgrade to a current version.
TunerStudio doesn't care what other programs are installed, or other versions for that matter. It is fine to run 2 versions of TS on the same computer. Just make sure you install them to separate folders.
Users browsing this forum: Sam280Z and 1 guest
