Launch Problem on 3.2.1 (SOLVED)
Postby Paul_VR6 » Mon Apr 16, 2012 3:50 am
I can't get launch to work on 3.2.1
Circuit verified by using another processor using 3.1.1 - works
Loading known good msq on 3.2.1 - no luck
Loading 'problem' 3.2.1 msq on 3.1.1 - works
Verified circuit using scope
Base msq from 3.2.1 and only updated launch pin to JS4 - no luck
I am out of time for the moment but the next step will be a 3.2.1msq on 3.1.1 and see what happens.
Datalog and various msq's attached.
2012-04-16_06.30.16.msq
3.2.1 msq launch inop
(84.06 KiB) Downloaded 4 times
base msq - no launch.msq
3.2.1 base msq launch inop
(83.87 KiB) Downloaded 4 times
working processor tune.msq
3.1.1 msq launch working
(83.66 KiB) Downloaded 2 times
-Paul
1995 GTI VR6 MS3/V3
kptuned.com - race-shop.net
Paul_VR6
Re: Launch Problem on 3.2.1
Postby Paul_VR6 » Mon Apr 16, 2012 3:51 am
Ran out of attachments, log attached.
2012-04-16_06.17.40.msl
Datalog toggling launch to ground a few times
(62.06 KiB) Downloaded 2 times
-Paul
1995 GTI VR6 MS3/V3
Paul_VR6
Postby Paul_VR6 » Mon Apr 16, 2012 3:59 am
Using both 3.2.1 msq's on 3.1.1 firmware shows launch working. :|
-Paul
1995 GTI VR6 MS3/V3
Paul_VR6
Postby jsmcortina » Mon Apr 16, 2012 4:55 am
It works ok on a Microsquirt module using the "FLEX" input.
Postby jsmcortina » Mon Apr 16, 2012 5:17 am
Tested on an MS2, works ok?
When I ground DIP40-pin30 (JS4) the launch in is active and the timing retards to 1BTDC. (With other conditions met.)
Postby Paul_VR6 » Mon Apr 16, 2012 1:44 pm
Even using the dated msq? Its almost like there is a pin conflict as I can see it go low on the scope.
-Paul
1995 GTI VR6 MS3/V3
Paul_VR6
Postby jsmcortina » Mon Apr 16, 2012 3:42 pm
Paul_VR6 wrote:Even using the dated msq? Its almost like there is a pin conflict as I can see it go low on the scope.
I concurr. That particular MSQ is triggering a problem in the code.
Entering those launch settings from scratch works ok. Using PE0/JS7 with that MSQ instead works too.
Postby jsmcortina » Mon Apr 16, 2012 4:03 pm
Far simpler than all that...
User level needs to be set to "Advanced"
Postby Paul_VR6 » Tue Apr 17, 2012 2:20 am
Set to Advanced, power cycled and it works.
Any rhyme or reason for that happening?
Thanks for the help James! Feel free to update the title to *SOLVED*
-Paul
1995 GTI VR6 MS3/V3
Paul_VR6
Users browsing this forum: No registered users and 4 guests
cron
