USB datalogger
Re: USB datalogger
deleted.
Re: USB datalogger
Having a fair amount of experience with the logger and some with MSIII SD logger, I still feel this product is relevant. I might use one with MSIII even because I am not limited by the field count
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
PF Tuning
Re: USB datalogger
A little upcomming bump, this weekend i'm about to start my engine after some winter work.
Will be very interesting to see how the logging of MS and Innovate AFR/EGT works in-car
![Image](http://www.rejsa.com/im/user/2007/2012-03-10-11-18-03_img_1173.jpg)
![Very Happy :D](./images/smilies/icon_biggrin.gif)
Re: USB datalogger
Huey
Are the boards still available?
Thanks!
Thanks!
Peter Florance
PF Tuning
PF Tuning
Re: USB datalogger
After test on a running engine and minor adjustment to firmware it works perfect to import the frd logg with afr and egt
![Image](http://rejsa.nu/im/user/2007/2012-04-05-22-12-17_mgv120327.png)
Will be a great tool this summer !![Yeah! :yeah!:](./images/smilies/icon_yay.gif)
Re: USB datalogger
Huey
Any idea as to whether this will datalog MS3?
The block size is 404; not sure if that overflows a variable or not
I tried to add the MS3 pre-1.1 beta 20 signature (MS3 Format 0233.003) to 0.1.1b but it didn't seem to log any data
Peter Florance
PF Tuning
PF Tuning
Re: USB datalogger
hmm looks like it does:Peter Florance wrote:Huey
Code: Select all
byte ochBlockSize
Peter Florance
PF Tuning
PF Tuning
Re: USB datalogger
So, I assume you got it working with MS3 ?
Huey
Huey
Dodge 2.2L MPI Turbo Power Running MSnS1/Extra.
Chevrolet 5.3 LM7 running MSnS2 /Extra
Chevrolet Twin Cam 4 cyl running MSnS2 / Extra
Home of the USB data logger---> http://www.msextra.com/forums/viewtopic ... 67&t=34901
Re: USB datalogger
no, but I'm wondering if I can make that variable 16 bit?Huey wrote:So, I assume you got it working with MS3 ?
Huey
I'm not much of a programmer; if I could have soldered something to it, it would have been working by now.
![Laughing :lol:](./images/smilies/icon_lol.gif)
Peter Florance
PF Tuning
PF Tuning
Re: USB datalogger
if I sayPeter Florance wrote:hmm looks like it does:Peter Florance wrote:Huey
ThanksCode: Select all
byte ochBlockSize
Code: Select all
word ochBlockSize
Peter Florance
PF Tuning
PF Tuning
Re: USB datalogger
Should not be a problem just change the ochBlockSize byte to word in the VAR section. You will also need to change the buffsize constant and the databuff.byte[0] and databuff.byte[1] variables as well. If I had a MS3 sitting around I would be able to help more.
Try this:
line 76 buffsize = 504
line 103 word ochBlockSize
line 240 databuff.byte[0] := ochBlockSize.byte[0]
line 241 databuff.byte[1] := ochBlockSize.byte[1]
Huey
Try this:
Huey
Re: USB datalogger
Thanks!Huey wrote:Should not be a problem just change the ochBlockSize byte to word in the VAR section. You will also need to change the buffsize constant and the databuff.byte[0] and databuff.byte[1] variables as well. If I had a MS3 sitting around I would be able to help more.
Try this:
Huey
I'll try it this morning!
Peter Florance
PF Tuning
PF Tuning
Re: USB datalogger
I tried that but there must be a user input variable that I haven't fixedHuey wrote:Should not be a problem just change the ochBlockSize byte to word in the VAR section. You will also need to change the buffsize constant and the databuff.byte[0] and databuff.byte[1] variables as well. If I had a MS3 sitting around I would be able to help more.
Try this:
Huey
When I review the signatures I get this:
MS1/Extra format 029y3 *********R39
MSnS-extra format 029q *********R39
MS/Extra format hr_10 **********R39
MS/Extra format hr_11b *********R39
MS2Extra Ser GSv24 A174
MSII Rev 2.88500 A112
MSII Rev 2.88600 A112
MSII Rev 2.88900 A112
MSII Rev 2.89000 A112
MSII Rev 2.89100 A112
MS2Extra Rev 1.0.2 A114
MS2Extra Rel 2.0.0 A153
MS2Extra Rel 2.1.0pA145
MS2Extra Rel 3.0.3rA169
MS2Extra Serial330bA172
MS2Extra Rel 3.0.3sA169
MS2Extra Serial321 A169
MS3 Format 0233.003A148
The MS3 should have been MS3 Format 0233.003A404 and it differs by 256 (byte)
Any ideas?
Thanks!
Peter Florance
PF Tuning
PF Tuning
Re: USB datalogger
Are you hard coding the new signature string at the end of the source code or entering it as a user signature string with the "E" command? I see a problem with the "E" command on line 776 and 808 where it says EEPROM.readByte and EEPROM.writeByte.
Huey
Huey
Re: USB datalogger
Oh, I see bigger problem the signature table is defined as "byte". I'll see if I can come up with a fix.
Huey
Huey
Re: USB datalogger
Yes hard coding.Huey wrote:Oh, I see bigger problem the signature table is defined as "byte". I'll see if I can come up with a fix.
Huey
Thanks; this will come in very handy with MS3!
Peter Florance
PF Tuning
PF Tuning
Re: USB datalogger
Is it something I can change?Huey wrote:Oh, I see bigger problem the signature table is defined as "byte". I'll see if I can come up with a fix.
Huey
I don't mind looking and compiling
Thanks!
Peter Florance
PF Tuning
PF Tuning
Re: USB datalogger
Sure, you have the source code. It would probably be best to split up the signature table and use the ID to offset into a new table defined as word that contains the byte count. By doing this I think it would require less reprogramming and save memory space because you are not defining the entire table as word. I have been meaning to work on it however, spring is here and I have so much to do. You can also change the ID numbering to something that makes more sense as a offset. Hope this helps.
Huey
Huey
Re: USB datalogger
Hello
Glad to see this is still going on.
Are there any units sold to the vendors of MS in Europe?
Is it possible to change from RS232 connector to usb connection with the MS unit?
Does a a usb to RS232 cable work both way's?
Ivan
Ivan
Re: USB datalogger
There are no vendors. You can buy them direct from me and I have sold several units out of the country. Just send me a private message with your address and I will give you the shipping cost.
The USB port only works in one direction.
Thanks, Huey
Thanks, Huey
