MS3 w/ MS3X steps 27 and 28 . 6.0 LQ4 engine help
Postby phoenix27101 » Mon Apr 23, 2012 10:22 am
My engine: Stock 2003 6.0 Chevrolet LQ4, 60,000 miles, running all stock injectors, coils, plug connecters, et cetra.
Board: MS3 3.0 with MS3X
Mission: sequential fuel, timing, and spark
I have read through all of the manual and its associated pages. Up until now, all directions have been self-explanatory. However, I require help on steps 27 and 28, which involve the board setup for trigger and spark. What is the best way to discern which tach input I should go with? From the best I can understand, VR input is the correct choice, but I don't understand what pullup is, or if it is required for my application.
After that, I assume, I need to set for high output. I see the required steps for single high current, but should I go with multiple.
Thank you in advance.
Chris
1979 CJ5, 6.0L LQ4, SM465, Dana 20, Reinforced AMC 20/ AMC 30
MS3X Megasquirt III I/O Expander Board, MS III Programmable EMS, PCB3.0, MS Stimulator Kit. V2.2
phoenix27101
Re: MS3 w/ MS3X steps 27 and 28 . 6.0 LQ4 engine help
Postby Matt Cramer » Mon Apr 23, 2012 10:33 am
Use the LS1 guide.
Postby phoenix27101 » Mon Apr 23, 2012 12:31 pm
Thank you for your help. I have looked over nearly everything, but there is a lot to take in. However, I am still unclear, do I want multiple high current outputs, or will the single be fine?
phoenix27101
Postby Matt Cramer » Tue Apr 24, 2012 4:59 am
LSx coils don't need high current outputs.
Postby phoenix27101 » Tue Apr 24, 2012 7:45 am
I'm not trying be be slow here. I just really don't want to make a mistake. Just to clarify, because I don't need high output, I can essentially skip step 28. Is this correct? Again thanks.
phoenix27101
Postby jsmcortina » Tue Apr 24, 2012 7:54 am
Do keep asking questions - better safe than sorry.
Yes, you can safely skip step 28. You will be using the logic spark outputs on the MS3X connector.
Did you get step 27 done ok? The "VR" input mentions what is required for LS1.
Postby phoenix27101 » Wed Apr 25, 2012 11:38 am
Yes, step 27 when seamlessly, I appreciate everyone's help.
phoenix27101
Return to Board assembly and testing
