How many engines running on MS2/Extra
Re: How many engines running on MS2/Extra
1981 DeLorean. Stock fuel system is Bosch K-Jetronic with Lambda. I removed that entire system (still need to remove associated wiring harness).
I am using the intake manifold, throttle body and fuel rails from a Renault of unknown make. Had setup shipped over from England. Injectors are high impedance, Accel brand. I am running 3.1.1, fuel control only. May do spark in the future. Installation isn't particularly pretty yet, but it is new and will be tidied up with time.
2000 vauxhall astra sri. 2ltr x20xev ecotec, rebuilt with z20let pistons/rods and injectors running stock z20let turbo and manifold but still using the x20xev dual track inlet manifold. running on microsquirt using 2.0.1p code. so far running 8psi boost. a little under power'd top end but i have a conservative spark map for now. been very reliable for the last 6wks or so with good mpg.
TVR Chimaera.
Fresh 4.6 V8 with 4.0 ltr pistons for higher comp, '500' ported heads, typhoon cam, full decat. 308bhp.
Now runs 12.4 @ 111 NA and 11.6 @ 125 on a 65 shot of nitrous.
My '62 VW Karmann Ghia runs a 1835cc T1 engine with home-made intake system/plenum and MS2Extra
It is about to be rebuilt using GSXR 600 ITBs over the winter.
Got mine going - 1991 BMW M50B20 E34 520i + it totally stock internals, 850cc injectors (coz I had them laying around), RB20 high-flow turbo, small intercooler, tuned by http://www.Garage7.com.au - 137rwkw, 250nm...
Thanks to Kat Philcox at http://www.facebook.com/KatPhilcoxPhotography for the great photos
I have my Microsquirt running MS2/Extra in and operational. Car is a 1996 Toyota RAV4. Engine is still bone stock apart from an Innovate LC-1 wideband O2 sensor.
Coming soon is 350cc injectors, T3 turbo, etc. Going for about 130kw, but we'll see what I end up with on a safe tune.
mk2 golf rieger, 2.8 12v VR6, gt35/40 turbo .50 ar, custom intake manifold (home made ), 60-2 trigger wheel + vw ignition module on stoc VR6 distributor, running on megasquirt 2 v3.0 fw 3.1.1 (for now, soon to be updated to the latest firmware), started on first atemp with no problems at all, yet the project isn't finished...
Vladimir
Vladimir
Now i can safely say that the car runs with the MS2/Extra ;)
Car is a Super 7 clone with Opel/Vauxhall C20XE, Hayabusa TB's, VAG/Audi 4-wire COP's full seq (using both distributor Hallsensor and VR sensor), CBR1100XX-injectors 335cc and an MS2/Extra 3.0
Mapping still to do.... winter here now and no winter tyres to the car...
Short film.... noisy regulator now taken care of ;)
http://www.youtube.com/watch?v=stqT5LCA ... re=related
Just got mine up and running on MSPNP- BMW 325 IX Touring turbo, 16 psi boost.
Still got some (alot) work to get cold idle tuned, but im reading up on topic.
1995 Ford Probe GT w/Turbo kit upgrade. All controlled via DIYPNP v1.1 w/MS2/Extra powered MicroSquirt module inside
Check out my success story link in my signature!
been running this setup since 2010... about to upgrade to the latest firmware to see what the fuss is all about ;-)
UPDATE:
now running firmware version 3.2.1 successfully
UPDATE:
~Daniel Kamilchu
1995 Ford Probe GT-Turbo, DIYPNP v1.1 Success story: http://www.msruns.com/viewtopic.php?f=8 ... 91#p145391
my engines run's well.
bmw 3e30 2000cc 6cil 2.0.0 code edis 6,
suzuki santana ,mono injector ,wastespark,2.1.0
alfa montreal.,dual dizzy,2.1.0
peugeot 205 swapped my16 engine,a/n,wastesprk,2.1.0
opel corsa c16xe 4tbi,a/n 2.1.0
fiat 124 spider ,fuel only,ljetronik pnp(stock case)2.1.0d
on work peugeot 309 my16........
thank's at ms people for support and development,have only success,ms is a fantastic device
another mk1 golf 16v KR, running ms2extra 3.3.0 gslender mod 2.4.4 + launch control mod nice and smooth on stock distributor (hall effect) , ABF intake manifold, ABF injectors and ABF cams
http://www.youtube.com/watch?feature=en ... Ul6IH_tkTE
http://youtu.be/dmcOIiz1MOA
http://youtu.be/adfbRShVL4M
cheers
cheers
1993 Honda Accord. Forged Wiseco Pistons. Billet H-Beam Rods. Ported and Polished Head. T3-T4 Turbo with Front Mount Intercooler. Denso 690cc/min Injectors. Running on a DIYPNP.
Did a DIYPNP setup on this datsun 510. SR20DET, complete rewire and tuck, 1000cc injectors, LS2 coils, 18G turbo, E85. just working out a small kink with the EBC.
the owner wanted his painter friend to redo the cam cover....it needs it and is an eye sore compared to the rest of the engine now!
cell phone pics, sorry
Andrew
Andrew
m3ltd0wn wrote:another mk1 golf 16v KR, running ms2extra 3.3.0 gslender mod 2.4.4 + launch control mod nice and smooth on stock distributor (hall effect) , ABF intake manifold, ABF injectors and ABF cams
cheers
the car in first video, is mk1 16v KR, but it's running MS1extra, no launch control, stock distributor, KR 50mm intake, 4-1 exhaust mani, 315cc injectors and 268° schrick cams..
I'm pretty sure, it's my car
but it's all history, now I'm playing with ITB's
https://www.youtube.com/watch?v=ffUuZBFtiSs
Re:
CrazyDave wrote:OK after some big style hair pulling out I finally got MSII Extra running on my VR6 Turbo.
Initial running seems very good but I'll have to wait until tomorrow to give it a good drive around.
I found the new ASE % of req-fuel table confusing, but only because I hadn't read James' notes properly (and noticed that it wasn't in ms anymore!).
For anybody else needing info for a VR6 here are my based trigger wheel settings.
Setup for a VR6 is as follows:
Trigger wheel settings
Single wheel with missing teeth
60 Teeth
2 missing
78 Degrees BTDC
Crank Wheel
Ignition Options
Trigger offset 30deg (This doesn't seem to move the timing at all???)
Skip Pulses 7
Falling edge
Toothed Wheel
Going Low
Wasted Spark
Output D14
would you be willing to send a fellow vr6er a msq for ms2 i just update from ms1 and something is not right? thanks
Mazda 626 2.0L FS, running MS2extra flawlessly for 60,000km. 15psi. Firmware 3.2.1.
http://xox1de.monchar.com
Running Megasquirt 2 Extra Code 3.0 XX
Calibra turbo 1991
Siemens Dekka 650cc Injectors
External wastegate
Omega 86.5mm pistons
Steel Rods, Arp Bolts
Garette Gt35 turbo
3" Pipework
Homemade wiring
Microsquirt V2
Oil Squirters.
Just got her up and running on microsquirt,
need abit of help tuning !! Pleaseeeeee
Its work in progress see the video
http://s1162.photobucket.com/albums/q528/alid2033/
Calibra turbo 1991
External wastegate
Garette Gt35 turbo
3" Pipework
Homemade wiring
Microsquirt V2
Oil Squirters.
There she is
