TS loses link on log start
It seems that every time that I try to start a log in 1.39 TS loses connection and locks up the comm port. Running VEAL works just fine, saving a msq while the car is running will do the same thing. I am running a DIYautotune serial adapter and a shielded usb cable.
MS3X v3 w/Ford IAC mod running MS3 1.41
Sig PIP TFI trigger with direct coil control, 60# highZ injectors
91 Ford Mustang, modified 5.0, 70mm turbo @ 11#s
Re: TS loses link on log start
It sounds like it may in someway be related to File dialogs?
Is consistent?
What look & feel are you using?
Can you send me a TunerStudioAppDebug.txt file?
Is consistent?
.LT401Vette wrote:It sounds like it may in someway be related to File dialogs?
Is consistent? yes
What look & feel are you using? default but it doesnt matter
Can you send me a TunerStudioAppDebug.txt file? not a problem, ill post it around 4:30pm cst
Here we are Phil, I hope it contains something useful.
Did this yield anything interesting? I did notice while reading though it that it cannot find a few files and seems to give up and shut down the connection. The files that it is loooking for are there and there is nothing wrong with my HDD.
Edit: I am uprgading to 1.41 as I type this, Ill let you know if it is still doing it.
After reading through the debug log it seemed more like a hardware issue than software. It appears that I was having issues with my current adapter dropping my link and screwing up link data with all of the noise in the car. I couldnt get any data from logs because the link would fail every time I made an attempt to log anything. Fortunatly my wife works for DigiKey (we live up here in far northwestern Minnesota), so I have easy access to lots of very good parts. The other morning I had enough and sent her out with a parts list, this morning I gave it a shot hoping for the best and I wasnt disappointed. The new parts worked flawlessly, no failures at all even with multiple WOT pulls.
I highly suggest that if you need something and want it to work, give this one a shot. Tested with WinXP on an Acer Aspire one netbook using the provided FTDI driver.
AE10409-ND USB 2.0 serial m/DB9 Digitus adapter
AE10644-ND USB 3.0 A male - USB 3.0 A female shielded 2m cable
