jsmcortina wrote:Please attach the actual csv log file.
jsmcortina wrote:What's your current status - is the config error gone and are you getting rpm ?
jsmcortina wrote:That was tooth log. Please take and post a composite log.
jsmcortina wrote:How long are you waiting?
jsmcortina wrote:So yes, there's no cam signal in that log.
You need that before you can run sequential.
Without it "Basic Trigger" will work, but nothing else.
jsmcortina wrote:The MS3X injector outputs can be used with sequential set to "Off"
The wiring _sounds_ ok as you have it. How did you configure the cam input in the Megasquirt ?
jsmcortina wrote:Which bit of "as per the manual" though ?
jsmcortina wrote:There's your problem then - the output from the module is not the same as a VR sensor.
Set the MS3X board the same as for LS1 (a few sentences later than the section you quoted.)
Users browsing this forum: quattrodaveuk and 0 guests
