black 89turbo wrote:yes
billr wrote:Referring to "Tune1.msq" posted 5/3/2012:
To the right of "BANK 1 Dead time @13.2V(ms)" I see a data-box with ".752" in it.
black 89turbo wrote:.
black 89turbo wrote:No go. I uploaded the table peter sent, set the dead time to .8. I also tried to up the PWM current all the way to 60 and still nothing. Take the dead time and put 7.0 in fires up without a hesitation.
billr wrote:Here it is, also the .msq Maybe it's a difference in the TS I'm using?
Peter Florance wrote:black 89turbo wrote:No go. I uploaded the table peter sent, set the dead time to .8. I also tried to up the PWM current all the way to 60 and still nothing. Take the dead time and put 7.0 in fires up without a hesitation.
which outputs are you using? MS3X or standard?
black 89turbo wrote:Peter Florance wrote:black 89turbo wrote:No go. I uploaded the table peter sent, set the dead time to .8. I also tried to up the PWM current all the way to 60 and still nothing. Take the dead time and put 7.0 in fires up without a hesitation.
Standard/main board. Not getting into the ms3x portion yet. lol rookie at ms
billr wrote:Make it simple for me, forget about the injectors P/Ns and top colors; how many ohms of resistance on one?
black 89turbo wrote:billr wrote:Make it simple for me, forget about the injectors P/Ns and top colors; how many ohms of resistance on one?
They ALL have 2.8ish give or take .1. I ohm them all out.
Peter Florance wrote:black 89turbo wrote:billr wrote:Make it simple for me, forget about the injectors P/Ns and top colors; how many ohms of resistance on one?
My 4G63 has ballast resistors
Oem haress, ecu & resistor box?
OEM harness, resistors and MS
Hmm, maybe put a resistor box in? I never used a resistor box using these injectors on AEM, Microwreck or helltech all 4 cars ran for year/years before either upgradding injectors ect. You have the same injectors correct? Your running MS2? Do you have a wiring diagram of the resistor pack put into play?
