Cannot run sequential message
Re: Cannot run sequential message
Postby jsmcortina » Mon Apr 30, 2012 10:18 am
That looks ok.
Postby jsmcortina » Mon Apr 30, 2012 11:03 am
I just made some updates to the manual page to hopefully make it a bit clearer how to set things up.
http://www.msextra.com/doc/ms3/ignition.html#ms3xcam
Postby charged3800z24 » Mon Apr 30, 2012 1:41 pm
jsmcortina wrote:I just made some updates to the manual page to hopefully make it a bit clearer how to set things up.
Thanks, so I just need to turn R11 3 turns Clockwise? That sounds to easy, lol.
charged3800z24
Postby jsmcortina » Mon Apr 30, 2012 1:55 pm
charged3800z24 wrote:Thanks, so I just need to turn R11 3 turns Clockwise? That sounds to easy, lol.
Fingers crossed yes.
Postby charged3800z24 » Mon Apr 30, 2012 2:40 pm
Update, I have spark and car run using STD inj outs using the Settings for toothed wheel and CAM setup. I checked with my NOID light and don't have anything on the MS3X inj outs. I verified Power is good. Rechecking the wiring now.
charged3800z24
Postby jsmcortina » Mon Apr 30, 2012 2:46 pm
With the same or different settings?
Make sure the MS3X plug grounds are grounded.
Postby charged3800z24 » Mon Apr 30, 2012 2:55 pm
jsmcortina wrote:With the same or different settings?
I feel dumb. I was working on the engine and moved wires around and cleaning things up and missed the ground wire for the MS3X board. I now have fuel and spark but engine stawls after start and idle up.
charged3800z24
Postby charged3800z24 » Mon Apr 30, 2012 3:40 pm
OK, I have fule and spark with CAM setup and MS3X injectors. I did a log and it looks like I am over fueling now. But something still seem off. Even in Batch fire mode. I am attaching the log and msq if it is helpful. i also noticed I had my old VE table loaded which would explain my over fueling.
2012-04-30_18.02.39.msl
(218.5 KiB) Downloaded 12 times
ms3x-test-4-30-12.msq
(159.95 KiB) Downloaded 13 times
charged3800z24
Postby jsmcortina » Mon Apr 30, 2012 4:06 pm
I don't see anything particularly wrong in that datalog? Seems to be idlling ok?
Postby charged3800z24 » Mon Apr 30, 2012 6:46 pm
jsmcortina wrote:I don't see anything particularly wrong in that datalog? Seems to be idlling ok?
Had to keep my foot on the pedal a bit. You can see the TPS was at a few percent. Noticed it was kinda rich, which may have been the issue. I'll load my previous VE table and see if it does better.
Edit: nevermind I found it in the manual what i was looking for.
charged3800z24
Postby charged3800z24 » Tue May 01, 2012 4:28 pm
OK, Tried to get full sequential working. I finally got the car to start, it idles up and then slowly drops to a stall. If I switch back to my STD injector outs it idles fine. I also had to bring IAC steps up just to get it to somewhat stay idling. Not sure why it is so different. Here is a log, I really don't know what to try. one other thing, the car start hard and some times back fires. Is it lean on cranking?
ms3x-test-5-1-12.msq
(159.97 KiB) Downloaded 13 times
2012-05-01_18.26.56.msl
(93.26 KiB) Downloaded 15 times
charged3800z24
Postby charged3800z24 » Sun May 06, 2012 6:07 pm
I got the car to idle fine and just have the iss of starting. Frank_Ster reminded me that on Basic trigger I have the option for GM-ByPass control. Toothed wheel doesn't have this option. Any chance this could be an option under toothed wheel? I can run a relay off the starter like Frank_ster did for now.
charged3800z24
Previous
Return to MS3 Development
Users browsing this forum: AbatelliCristian and 0 guests
