Spark 'booster' (PNP circuit)
I have been testing out a circuit board that implements an improved version of the PNP drive shown in the MS2/Extra manual that is suitable for driving the VAG COPs.
The circuit could be used as an add-on to the MS3X to drive this type of coil or mounted internally within an MS2 instead instead of prototyping the additional transistors.
What I'm wondering is whether there's any interest in such a board for retail. Plus would it be best pre-assembled surface mount or supplied as a bare PCB for through-hole do-it-yourself assembly?
tpsretard2
Re: Spark 'booster' (PNP circuit)
Post by tpsretard2 »
i might be interested, my subaru cops have the same problem as the vag cops
colossusuk
Post by colossusuk »
I'd like one of these boards if possible, at the moment I'm using a ford wasted spark pack but I would like to run VAG COPs on my VAG engine :)
Doesnt matter to me how it comes assembled or not - would assume it would be cheaper to assemble it ourselves?
Cheers,
James.
Paul_VR6
Post by Paul_VR6 »
I would take a bunch. Pm me.
-Paul
BZR Se7en
Post by BZR Se7en »
Yes, I'd be keen in PCB form. As long as it had 4 coil drivers (or maybe 2), and maybe some other useful circuit like boost control or Tach, or 4 injector drivers for sequential.
In other words, a board that would be ideal for a 4 cyl VAG engine.
PCBs in and I've assembled a couple.
The board is designed to be used either internally screwed to the case lid or in an external box. It uses either a 5V supply or 12V supply with on-board regulator.
lotus23C
Post by lotus23C »
What is different about the circuit to what is published in the manual?
thanks
Currently Lotus 23C replica Audi 1.8T MS 2 v3 Sequential COP and ignition.
Lotus 7 replica 4age 20V blacktop MS2 v3
It contains current limiting on the output and has the input buffer transistors in place. It could be used externally from an MS3X or internally from the CPU in MS2 installs.
teg
Post by teg »
I have just ordered a MS3X and I 'm running with 4 VAG COP's, so I'm interested! :)
Opel Kadett C City 2.0 16V Turbo
I'll put together some pricing in a bit.
T3Bunny
Post by T3Bunny »
I am also very interested. Has the extras manual been updated to reflect the improved circuit design? If not, would you be willing to post a schematic up here? I am currently upgrading to full sequential if I can sort out a reliable cam synch. If not, guess I will need to run a coilpack instead.
tpsretard2 wrote:i might be interested, my subaru cops have the same problem as the vag cops
Interesting, I can't say I have seen a Subaru with COP! But then most of the ones I work on tend to be older models.
1977 Rabbit (retired)
1991 Cabriolet (retired)
tpsretard2
all STI's bar one model came with COP's
pre 99 was simple cops with external ignitors. the ms3 triggers these fine.
after that it has built in ignitors and the ms3 will not fire them directly.
OK, here's my pricing for this first trial batch. In GBP / USD
Bare PCB = £7 / $11.2
Loose kit of parts w/o wires or regulator = £9 / $14.4
Loose kit of parts w/o wires = £12 / $19.2
Assembled without regulator = £25 / $40
Assembled with 250mA regulator = £28 / $45
International postage at cost. Airsure to US is ~$12
davcol
Post by davcol »
can this unit work with c.o.p. direct drive setup and boost its output :?:
m2 extra v3.57 3sgte full sequential injection V1.1A P&H Board
full sequential spark low current c.o.p.
holset turbocharger
teg
Post by teg »
Where is schematics for this? I would like to see it..
lotus23C
Post by lotus23C »
I never thought to ask before, this is for 3 pin dumb VAG COPs - right?
lotus23C wrote:I never thought to ask before, this is for 3 pin dumb VAG COPs - right?
Nope. 4 pin logic VAG COPs.
For 3 wire COPs you need an ignitor such as some BIP373s or the Quadspark from DIYautotune.
davcol
Post by davcol »
Will this circuit drive the toyota denso 4 pin cop ignition coil with built in ignitor ?
If yes, what would process of purchasing? do you used paypal, that would be good. :D
holset turbocharger
davcol
Post by davcol »
i would like try this on my project :D
holset turbocharger
davcol wrote:Will this circuit drive the toyota denso 4 pin cop ignition coil with built in ignitor ?
Usually the Denso coils don't seem to need a booster.
