jsmcortina wrote:Why ADC counts though? That's an internal artifact.
My plan was g/s against volts on a 32 point curve. i.e. merge the calibration table and correction curve into one exposed curve.
Frequency input MAFs are already supported and would use the same curve, where "0V" = minimum flow frequency and "5V" = maximum flow frequency.
Air temp adjustment seems fine.
The cleaning up of the load values is a good call too.
bubba2533 wrote:
Edit: I would say 32 point may not be enough resolution. I'm just going by OEM's because Subaru has a 64 point transfer curve. (transfers the voltage to a g/s)
Lambda - 1 1 1 1 1 .95 .95 .95
RPM - 1000 1500 2000 3000 4000 5000 6000 7000Lambda - .95 .90 .90 .85 .82 .82 .78 .78
RPM - 1000 1500 2000 3000 4000 5000 6000 7000Lambda - 1 1 1.05 1.05 1 .95 .95 .95
charged3800z24 wrote:lbs/min and full GM MAF support (if it isn't allready).
bubba2533 wrote:I'm not sure how but it would help to have the frequency MAF's be as similar to 0-5v MAF's as far as calibration curves and such.
ie. they use the same calibration curve, but there is an option to pick 0-5v and frequency. And this would automatically change the units of the curve to hz instead of g/s. (don't have a frequency MAF so I'm just guessing on units)
techsalvager wrote:charged3800z24 wrote:lbs/min and full GM MAF support (if it isn't allready).
can you explain what you mean by full GM maf support?
charged3800z24 wrote:techsalvager wrote:charged3800z24 wrote:lbs/min and full GM MAF support (if it isn't allready).
Last I heard the GM MAF wasn't supported in any final release. I didn't see it mentioned in the manual either. That's why I said (if it isn't all ready). My 3800 has the MAF built into the Throttle body and would be a much easier install
techsalvager wrote:in maf mode I would suggest turning the VE table into the MAF commanded fuel table.
I don't agree with using the ve table with maf sensor because a properly setup one covers its bases fine. People that have to add or mess with idle more then likely have improper injector settings or an install issue.
The current way makes the afrtarget table the commanded fuel table, so you lose functionality if you want to run closed loop fueling while using maf
I commonly run stoich into boost, but when I hit it I want the fuel to drop to a certain determined amount.
In reatlity you don't really need a commanded afr table, you could get away with a commanded power enrichement map and have mostly everywhere else be targeted at stoich or whatever set value you wanted.
