MS3 beta 1.0.6 released
This is a bugfix release on 1.0.5. Assuming it tests ok, the aim is to promote it to "release" quite quickly.
Changes:
Fix injector trim pulsewidth overflow also allows larger pulsewidths
SDcard VBR support
The pulsewidth issue was only apparent with very large (> 43ms) pulsewidths during or just after cranking and only if injector trim was enabled.
The SDcard changes bring back a few tweaks from the pre-1.1 development code.
The zip can be downloaded from http://www.msextra.com/doc/ms3/files/be ... -1.0.6.zip
The new firmware loaders are included as standard.
MG four six eight
Re: MS3 beta 1.0.6 released
Post by MG four six eight »
Just reporting back that 1.0.6 is working well! Seq cranking pulse width readings are normal and the engine starts right up, compared to 2.6 ms (during no start) when the bug would show up. Thanks James :)
Bill
frank_ster
Post by frank_ster »
i appear to be having an issue,
i changed over to this version a few days ago.
only issue i have is with the pid controled ego correction.
my target afr is 14.0-1 at idle 14.7 everywhere in cruse under 100 kpa and then drops down to 11-1 in 200kpa.
when ideling it seams the target is 13-1 and in cruse its 14-1. it stays at these numbers regardlss of pid settings. even with proportinal to 100 intergral at 0 and deritive at 0 it still follows the same.
as soon as i set to simple ego it works as it should it adjusts to my target afr's.
so i have a work around just reporting my issue.
i can post 2 data logs and my msq upon request
2005 subaru legacy with buick grandnational engine and awd :D
Nothing was changed relating to EGO control.
frank_ster
Ok but why is the pid control ego not working ? i did not try 1.0.5 maybe something in that or previous version that was changed ?
teg
Post by teg »
I don't think PID has anything to do with targets?
Opel Kadett C City 2.0 16V Turbo
adamnreeves
Post by adamnreeves »
jsmcortina wrote:This is a bugfix release on 1.0.5. Assuming it tests ok, the aim is to promote it to "release" quite quickly.
How quickly we talking? Been holding off installing 1.0.6 waiting for the release.
Westfield SEiGHT 4.6 Stage III
Running Megasquirt3 Wasted Spark using EDIS-8 Firmware MS3Extra 1.1.1
Build site
Why?
The code won't change aside from the word that appears in the title bar.
adamnreeves
So just a tag then. I'll update over the weekend. Cheers.
Build site
adamnreeves
I've upgraded and started her up in the garage.
Build site
