However, if 'password' security is implemented, or some method to lock the microcontroller from reads/writes after the code/tune is written, then this will be MUCH more difficult for the end-user to read out the tune/etc. Of course, they won't be able to write it either, but - hey, for $10k, the TUNER will do all the writing to the ECU.
Rob_B wrote:Edit: With MS being open source I would think it would be difficult to make a good protection that won't be cracked within a few weeks.
That is 100% incorrect. If the mechanism is a simple "everyone knows it, and it's coded in the code" password, then, yes, it would be available, as well as absolutely useless. If it's done correctly, then anyone can view the code, and confirm that security is done correctly, and take solace in knowing their expensive tune can rest well on the processor without prying eyes viewing it.
Now, all that said, I'm 100% against addition of any 'security mechanism' to the release code, as I'd rather see coding resources dedicated to fixing bugs, enhancing/adding useful features that can benefit the most people using MS. If someone wanted to fork a "secure line" code from the available code releases, then more power to them, and so be it - the power of having the source code available, and if they are making $10k on tunes, THEY can afford to code the security in...
