Tunerstudio shows fullsync about every third start and I wonder why.
Perhaps there is like a problem with just the TS indication. TS never shows half-sync just only not goes green on the full-sync gauge.
I've runing on 1.06 and are now trying with 1.1 pre20 but with the same behavior. I've 2 cars with this problem.
Setup is 4cyl, vr36-1, hall-gt1, ls2-cop
Half and full indication
Bmw 2002, 4cyl-turbo, itb, ms3x, seq cop ls2, 36-1, high ohm, lc-1, 401whp
Re: Half and full indication
composite log for half vs full
Not showing green full sync means that it is only half-synced.chellquist wrote:TS never shows half-sync just only not goes green on the full-sync gauge.
With your wheel mode it means that it hasn't yet received the cam signal and will be running wasted-COP ignition.
I'm not able to replicate the symptoms you report on the bench.
If I unplug the cam wire on the stim and increase rpms from zero, it shows as half-sync. When I plug the cam wire in it immediately changes to full sync.
Your comp logs appear to show a valid cam signal.
EDIT: You'll be able to tell if you are in wasted-COP by hooking up a strobe to one of your ignition leads. The rpm will show double.
