Concerns over the air density correction calcs
(Runs on MS2 and Microsquirt)
Postby gslender » Thu May 31, 2012 1:24 am
Was looking at the code in MS2 and me thinks I've found a bug in the air density correction code...
There is a cast to an unsigned char (ccor) when in the cor calc above it could be less than 100 and therefore "cor - 100" could be -3 and when cast to unsigned char this would be a bad/incorrect value yeah? Even worse, the sign from the previous calc is also lost by making it unsigned.
Code: Select all
int aircor_eq(int mat)
    signed int cor;
    signed char ccor;
    // returns air density correction from equation in % (100 is no correction)
... <snip> ....
        cor = 529700 / (mat + 4597);
// Changed for 3.0.3w to ignore this (unused) setting always use degF internally.
//    else  {                          // deg C
//        cor = 293200 / (mat + 2732);
    if (flash5.airden_scaling) { // only if non-zero
        ccor = (unsigned char)cor - 100;    /// <<<<<<< this shouldn't be cast to an unsigned char !!!
        cor = ((signed int)(ccor * flash5.airden_scaling)) / 100;
        cor = cor + 100;
    return (int)cor;
Mazda MX5 91 NA6 LE | M45 Mini SC | 4-2-1 Extractors & HI-Flow Exhaust | HSD HR Coilovers | MS2 DIYPNP Full Seq running ms2extra pre3.3alpha5 gslender v2.8 | Toyota COP | RX8 425cc Inj | W2A Intercooled
gslender
Re: Bug found in air density correction
Postby Peter Florance » Thu May 31, 2012 3:21 am
subscribed to topic
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
Check your grounds: http://www.msextra.com/doc/general/grounding.html
Peter Florance
Postby Zaphod » Thu May 31, 2012 3:47 am
Are the MS2 and MS3 MAT corrections the same?
fun is not a straight line
Sven
http://www.mx-5club-sachsen.de
http://miata.cardomain.com/id/svenmx5
NB-1998-1,6-Garrett T25 HGP Turbo Stage I
Zaphod
Postby gslender » Thu May 31, 2012 3:53 am
Source for the very latest ms3 code isn't released, so can't say, but a lot of the code often is similar.
gslender
Postby Peter Florance » Thu May 31, 2012 4:05 am
What are the implications? Is it something I can check in a log?
Thanks!
Peter Florance
PF Tuning
Peter Florance
Postby jsmcortina » Thu May 31, 2012 4:08 am
gslender wrote:There is a cast to an unsigned char (ccor) when in the cor calc above it could be less than 100 and therefore "cor - 100" could be -3 and when cast to unsigned char this would be a bad/incorrect value yeah?
The cast is on the _input_ to, not the output from that calc. (EDIT: Although at a glance I'm not sure why I added that cast.)
The previous calc is a positive number divided by a positive number - how can that give a negative result?
Have you checked the generated assembler for this code?
Have you tested it to see what range of values are produced?
Postby gslender » Thu May 31, 2012 4:22 am
Ahhh, true - precedence says the cast happens first, then the subtraction... good point. My bad. :oops:
gslender
Re: Concerns over the air density correction calcs
Postby gslender » Thu May 31, 2012 8:43 pm
Thought I'd share what the values do so that you can see for youself how the code impacts fueling based on tempature and the various % in correction scaling.
The fueling is scaled by the % calculated in the last two columns (one is for 100% MAT scaling, the other is values used at 50% MAT scaling).
I'll admit I was quick to think a bug exists when in fact the odd unsigned cast through my thinking around precedence.
I am now wondering if the lack of resolution makes any difference - note how the band of no correction (shown around 68-70F where it is at 100% correction) is only a small area as you change from 100% to 50% MAT scaling. When you look at 32F, the resulting correction is more pronounced (perhaps as it should be), but should the change to scaling have no impact to the correction seen at 64F deg, which is 1% additional fuel regardless of whether you have 100% scaling or 50% scaling? That seems wrong yeah? but perhaps the resulting fuel difference is negligble too... in which case when does it have an impact?
Code: Select all
F   C   100%    50%
      Corr   Corr
32   0   108   104
36   2   107   103
40   4   106   103
44   7   105   103
48   9   104   102
52   11   104   102
56   13   103   101
60   16   102   101
64   18   101   101
68   20   100   100
72   22   100   100
76   24   99   99
80   27   98   99
84   29   97   99
88   31   97   98
92   33   96   98
96   36   95   98
100   38   95   97
104   40   94   97
108   42   93   97
112   44   93   96
116   47   92   96
120   49   91   96
gslender
Postby ol boy » Thu May 31, 2012 10:32 pm
I'm glad you did this table. I can now see the % of change in the curve. I've changed my ini file to allow lower than 50% scaling, I run mine down around 20% and use the correction table to fine tune. I think heat soak issues are causing rough starts and poor running after a hot start. It's getting warm in southern AZ. 108*F tomorrow.
289 SBFord, Dual GM TBI, 8 LS2 coils in waste spark and a TURBO!, MS2extra 3.3.0alpha10 code
ol boy
Postby jsmcortina » Fri Jun 01, 2012 3:02 am
In MS3 we already changed the 'correction' curve to 0.1% steps. In a future code release we'll likely merge the built-in calculation and the correction curve.
Postby gslender » Fri Jun 01, 2012 3:18 am
Cool. Looks like a fairly easy thing to do... any problems if I give that a crack?
gslender
Postby aaronc7 » Tue Jun 05, 2012 6:07 am
any progress? :)
aaronc7
Postby gslender » Tue Jun 05, 2012 12:58 pm
Well I was hoping I'd get a blessing first, so I might look into it, but alas would prefer Ken or James to be ok with that first.
G
gslender
Postby muythaibxr » Tue Jun 05, 2012 1:38 pm
I'm OK with it, just watch for overflows.
muythaibxr
Postby robd » Wed Jun 06, 2012 9:01 am
I'd be very keen to try out a new code with this change in it for MS2. :)
robd
Postby gslender » Thu Jun 07, 2012 4:08 am
Ok, I've got a build I'm testing right now. Shouldn't be too much longer 8)
G
gslender
Postby aaronc7 » Thu Jun 07, 2012 7:55 am
woohoo! Were you able to add any of the Air density correction taper features like I had mentioned? I've been looking into it on my own...but I am not a programmer, so it's going pretty slow. I've found it in the MS1 code and now looking to see how to incorporate that into MS2 existing code. But... if you're been working on it already then I suppose I'll just stop and wait!
aaronc7
Postby gslender » Thu Jun 07, 2012 1:32 pm
aaronc7 wrote:woohoo! Were you able to add any of the Air density correction taper features like I had mentioned? I've been looking into it on my own...but I am not a programmer, so it's going pretty slow. I've found it in the MS1 code and now looking to see how to incorporate that into MS2 existing code. But... if you're been working on it already then I suppose I'll just stop and wait!
If you mean a RPM based taper, then yes.... I've extended the basic scaling to be 5 pt rpm based. Defaults to 100% like the single value scaler, but the curve can be changed to any % at any rpm so you can zero at idle 100% at 1000rpm sliding to zero at 4000 etc.
G
gslender
Postby aaronc7 » Fri Jun 08, 2012 5:20 am
awesome, can't wait!
too bad my motor is still being built
aaronc7
