rabid wrote:I didn't look at the logs. Is the req fuel now about 30% bigger than the gasoline tune? Are your injectors larger? Duty cycle ok? The tables will change and lean out a bit on some areas and rich in some areas. The spark advance will need to be advanced. E85 loves spark advance. Cold starting will need more fuel. Tons more fuel below about 50 degrees F. Epic levels of fuel below 30 F.
I have a 1600cc engine with 1200cc injectors. It runs around 3.1 req_fuel and makes high vacuum areas of the map a pita. Gasoline was about a 2.2 req_fuel
techsalvager wrote:why did you use 9.x instead of 14.7 for the req fuel?
rabid wrote:e85 can clean anything out of the tank and plug the filter.
racingmini_mtl wrote:Actually, the req fuel should be done with the AFR for the fuel you're using, i.e., 9.x for E85. This is a computation that is completely external to the MegaSquirt so you need to use the real AFR for Lambda = 1.0. For all other AFR values, you need to assume that 14.7 is Lambda = 1.0 since that is what the wideband controllers use as default.
Panoles1 wrote:That is what I did.. I used 9.5 as my target AFR to achieve the req. fuel...
racingmini_mtl wrote:Panoles1 wrote:That is what I did.. I used 9.5 as my target AFR to achieve the req. fuel...
Do you mean that you set AFR to 9.5 in the window where req fuel is computed? And that you did NOT set your AFR target to 9.5 in the AFR target table, right?
techsalvager wrote:did you change your wideband to read AFR values based on e85?
Panoles1 wrote:techsalvager wrote:did you change your wideband to read AFR values based on e85?
The way i understand it... I shouldn't have to mess with the wideband sensor or gauge, as they are only measuring Lambda and displaying that reading as an AFR for either fuel types. Am I missing or not doing something correct?
techsalvager wrote:Panoles1 wrote:techsalvager wrote:did you change your wideband to read AFR values based on e85?
if you didn't mess with the wideband and change reported AFR to be for e85, then lambda will = 1 at 14.7 AFR still which means you would need 14.7 in req fuel as well.
techsalvager wrote:if you didn't mess with the wideband and change reported AFR to be for e85, then lambda will = 1 at 14.7 AFR still which means you would need 14.7 in req fuel as well.
