3SGTE hard to start, runs fine
Re: 3SGTE hard to start, runs fine
Postby nuk1ear » Sat Jun 09, 2012 5:05 pm
i never noticed my case getting very hot. are you using MS3+MSx?
nuk1ear
Postby Kennyx » Sun Jun 10, 2012 12:41 am
It have nothing to do with ms3 .... i put it at hot place ... so the casing absorb a lot of heat when i park the car under strong sun light .. so billr was suggest that the heat may cause those bad soldering to crack ... which is pretty logic for my weird problem..
KennyX
Endless learning on every kind of New Technology
Kennyx
Postby Kennyx » Sun Jun 10, 2012 10:31 am
aww god ... i check and make sure all the solder is nice and clean, even try to add more solder to those "weak " soldering .. it still coming back to haunt me ...
Kennyx
Postby benckj » Sun Jun 10, 2012 9:03 pm
Easy to get 'cold joints' on solder connections if iron is not hot enough or not enough solder is used. Inspect carefully each joint with a magnifying glass and touch up any which look dull or only have solder partially around the joint. Also look at places where the solder could bridge across shorting to other connections or breaks in the tracks on the board. You would be surprised about the defects which are undetectable to the naked eye.
benckj
Postby Kennyx » Mon Jun 11, 2012 1:50 am
im sure all my welding are in perfect form .. my full time job was electrical technician :lol:
I guess beside welding ... i need to look for the polarity of cap and or chip also...well..everyone can make mistake .. i'll try to check on the 12v power source when cranking the engine ..because when problem comes...throttle response will goes sluggish like hell and it will not go away..turn off the key and start up the engine again will clear the error ...d*** it
KennyX
Kennyx
Postby billr » Mon Jun 11, 2012 8:44 am
Is your main 12V relay socketed? How about swapping that with another; or temporarily jumpering the contacts to see if it is a problem in the (relay) coil circuit?
billr
Previous
Return to MS3 General Support
Users browsing this forum: Bing [Bot] and 2 guests
