I have a problem with the Pw I think.
I have a 410 engine with a KB supercharger with propane injectors with P+H boards.
The idle PW is about 4.7 but when I am going to accelerate it is going up to 28 Sec it is not even at WOT then.
The engine is running really rough then, so I don't want to try it at wot.
The engine had a rough idle before I have tried to use the Idle advance( I hope I have done right? )and to lower the injector small pulsewidths, I dont have the good value for it.
The value for the injectors I get fro Bigas are :minimum impulse 2,8ms , Speedup 4ms,opening time 2ms ,close time 1ms, coil 3 ohms,
How I must use this data?
test.msq
- (139.29 KiB) Downloaded 9 times
Thanks and greetings,
Erik.
My MSQ and log file are here :
