Shadow Logger can't sign in on Galaxy Nexus
85Bertone
Post by 85Bertone »
I'm running Shadow Logger 1.14 on a Galaxy Nexus (Andriod 4.0.4) and cannot sign in to upload files. When I try it says "Unable to authenticate error code 0 message null". This also would happen when I was running V.1.12. logging in on my EVO 4G works fine. Logging into the web site also works fine. Another issue I'm having only on the new phone is the "start reads" and "start logging" buttons go away and don't come back when tapping the screen. Any suggestions on how to make sign in work?
Matthew
ranster
Re: Shadow Logger can't sign in on Galaxy Nexus
Post by ranster »
I can confirm the same behavior on my Galaxy nexus.
Went back to 1.11 for now.
Turbocharged BMW E36/5 - Megasquirt 3
Fiat 128 Coupe ITB - Microsquirt V3
Post by LT401Vette »
There does seem to be an issue here, My 4.0.3 Android is doing the same thing. My 2.3 is working fine.
I will look into it.
318aye
Post by 318aye »
Same issue, brand new nexus with 4.0.4. worked great on my old droid x. any update here?
Yeah, I found the problem, it is a simple enough to fix. It is a change in Android, so will happen on all 4.0.
I was on Business travel last week so couldn't fix it, now I need to get a TS issue out of the way, but should have a fix for this in the next day or 2.
318aye
Post by 318aye »
Thanks! Super helpful as always.
Ok, 1.15 should resolve this:
http://tunerstudio.com/index.php/downloads
ranster
Post by ranster »
Same behavior with 1.15 on my Galaxy nexus running stock 4.0.4 android rom.
Yes there does seem to be a problem logging on from the File Manager.
You should be able to log on from the main screen. I'll have a fix for the file manager shortly.
318aye
Post by 318aye »
Got 1.16 off the site today. Works great. Thanks Phil.
85Bertone
Post by 85Bertone »
Just downloaded 1.16. Seems to be working fine. Thanks for the quick fix.
ranster
Post by ranster »
Well, maybe something is wrong with my phone but i get the same error in 1.16 while trying to u/l a log.
Let me know if you need some info/details from my phone!
Ran
Yeah, looking at it, your error message does not match the problem in the FileManager. It looks like the Internet Access is failing on yours.
Is there any reason you know of that the app might not be able to reach the internet?
ranster
Post by ranster »
LT401Vette wrote:Yeah, looking at it, your error message does not match the problem in the FileManager. It looks like the Internet Access is failing on yours.
It does reach the net as i get a successful log in message when i fire up the app.
Same phone with 1.11 works perfectly.
Does anyone else have Gnex and share the same behavior?
Interesting...
That would be the same call, just from a different place. I may need to put some more debug info in.
While it seems to be working for several of us, I'll assume if it doesn't for you, it doesn't for someone else :(
Is it only from the FileManager, or does it not work from the main screen if you click the Menu and Sign On?
ranster
Post by ranster »
Interesting...
File manager only.
Thanks!
