Shadow Logger can't sign in on Galaxy Nexus
I'm running Shadow Logger 1.14 on a Galaxy Nexus (Andriod 4.0.4) and cannot sign in to upload files. When I try it says "Unable to authenticate error code 0 message null". This also would happen when I was running V.1.12. logging in on my EVO 4G works fine. Logging into the web site also works fine. Another issue I'm having only on the new phone is the "start reads" and "start logging" buttons go away and don't come back when tapping the screen. Any suggestions on how to make sign in work?
Matthew
Matthew
Re: Shadow Logger can't sign in on Galaxy Nexus
I can confirm the same behavior on my Galaxy nexus.
Went back to 1.11 for now.
Turbocharged BMW E36/5 - Megasquirt 3
Fiat 128 Coupe ITB - Microsquirt V3
There does seem to be an issue here, My 4.0.3 Android is doing the same thing. My 2.3 is working fine.
I will look into it.
Same issue, brand new nexus with 4.0.4. worked great on my old droid x. any update here?
Yeah, I found the problem, it is a simple enough to fix. It is a change in Android, so will happen on all 4.0.
I was on Business travel last week so couldn't fix it, now I need to get a TS issue out of the way, but should have a fix for this in the next day or 2.
Thanks! Super helpful as always.
Ok, 1.15 should resolve this:
http://tunerstudio.com/index.php/downloads
Same behavior with 1.15 on my Galaxy nexus running stock 4.0.4 android rom.
Yes there does seem to be a problem logging on from the File Manager.
You should be able to log on from the main screen. I'll have a fix for the file manager shortly.
Got 1.16 off the site today. Works great. Thanks Phil.
Just downloaded 1.16. Seems to be working fine. Thanks for the quick fix.
Well, maybe something is wrong with my phone but i get the same error in 1.16 while trying to u/l a log.
Let me know if you need some info/details from my phone!
Ran
Ran
Yeah, looking at it, your error message does not match the problem in the FileManager. It looks like the Internet Access is failing on yours.
Is there any reason you know of that the app might not be able to reach the internet?
It does reach the net as i get a successful log in message when i fire up the app.LT401Vette wrote:Yeah, looking at it, your error message does not match the problem in the FileManager. It looks like the Internet Access is failing on yours.
Same phone with 1.11 works perfectly.
Does anyone else have Gnex and share the same behavior?
Interesting...It does reach the net as i get a successful log in message when i fire up the app.
That would be the same call, just from a different place. I may need to put some more debug info in.
While it seems to be working for several of us, I'll assume if it doesn't for you, it doesn't for someone else
Is it only from the FileManager, or does it not work from the main screen if you click the Menu and Sign On?
File manager only.LT401Vette wrote:Interesting...It does reach the net as i get a successful log in message when i fire up the app.
Thanks!
