So maybe it could return search results that quoted the VE value and at what time's in the logs you hit these cells and maybe even a summary of some sorts.
Main reason for thinking this is I'm wondering if my ITB load switchpoints are maybe wrong so I could be tuning the same area of the VE in both MAP and Alpha-N areas and ending up with different AFR's! Not sure if this is possible at all!
Cheers
Rob
P.S. I can see you can do a search on say Load and other fields at the moment, but does that just take you to the first result? Also what would be great is if in the search results it showed you each time stamp, then maybe a button so you could jump to that area, but while retaining the search box, much like when the VE Analyse screen opens.
Edit: Just seen this topic. Could the above be added as a feature request if you think it's worthwhile and isn't already do-able?
