How many engines running on MS2/Extra
Re: How many engines running on MS2/Extra
1991 Ford Mustang convertible LX 5.0
GT40P intake ported and gasket matched
Aluminium Holley Systemax heads (2v 1.94in/1.60ex 1.6rrs) ported and gasket matched
FMS E303 cam
Stock forged factory shortblock
Single 70mm journal bearing turbo, 46mm gate, 50mm BOV, large A2A intercooler.
Art Carr C4 reverse manual automatic transmission
3" downpipe split to two 2.5" through box mufflers with turndowns.
FMS 3.73 final gears with a 8.8 trac-lock carrier.
My mistress
FMS E303 cam
My mistress
MS3X v3 w/Ford IAC mod running MS3 1.41
Sig PIP TFI trigger with direct coil control, 60# highZ injectors
91 Ford Mustang, modified 5.0, 70mm turbo @ 11#s
that is one badd ass mustang, whats the size of the throttle body? is it 76mm?
if so you got a part number for the entire inlet? or you got a spare i can buy?
75mm IIRC with no bypass hole on the butterfly. I'd have to look it upalid2033 wrote:that is one badd ass mustang, whats the size of the throttle body? is it 76mm?
- MS2-Extra 3.1.1
- Innovate LM-1 mimicking LC-1
- Speed density algorithm
- Siemens Deka 60lbs injectors
- A1000 Fuel pump
- A1000 Fuel pressure regulator set to 35psi base fuel pressure with boost port connected for 1:1 rising rate.
- 400KPA map sensor
- OEM coilpack w/o control module
- Autolite 3923 gapped to .024
- OBD1 TB
- Schimmel Short runner intake
- Autotech 262 cams
- Garrett T04Z, .96ar undivided hotside
- 3" turbo back w/hi flow catalyst
- Tial 35mm Wastegate/50mm BOV
- 9:1 compression
- 20lbs boost
-Andrew
Looks like fun
1998 Ford Escort ZX2
2003 Ford Focus Engine, Stock 5 speed transaxle. MS2 on a v3 board with a Madhu Fuel Pump Controller, allowing me to run returnless fuel. Fuel pressure is a stable 43PSI (corrected to manifold pressure). Tuning for fuel efficiency. Currently getting 39/47 MPG with it, working on breaking 50 MPG.
Daily driver, home at 8500 MSL, work at 10300 MSL, but must decend to 7900 MSL to get out of town. Gotta love the Rockies.
Mercedes 190E 3.0-24v turbo. Running MS2 on v2.2 board (MS2-Extra 3.1.1), t3/t4 turbo, 6x630cc/min injectors, 60-2 trigger wheel with VR sensor , zeitronix wideband.
Mercedes-benz 190E 3.0-24v turbo @ 8 psi
1989 Vauxhall Astra GTE
Ecotec X20xev engine (early type), using a later simtec 56.5 Hall effect crank sensor.
X20XER cams Redrilled pulleys to adjust timing.
Homemade bike based ITBS and helmholtz airbox.
Inboard and outboard injectors (not setup yet).
The list could go on for a very long time, not a lot is standard as most bits have been fettled especially the suspention.
Astra Gte by ben a.k.a me, on Flickr
The air filter is not there permantly..
Astra GTE by ben a.k.a me, on Flickr
http://www.astra-mk2.com/forum/showthre ... te-rebuild
upgraded my car's motor, from 2.0 8v to 1.8 16v G60, running on ms2 v3 management.
How does it run? How many horses? Stock, they were 205 or 210, but, not sure you created this one within stock spec.
Nice project ;)
Nice project ;)
stock 16vG60 has 210bhp , mine... well I really don't know yet, I'm still breaking in the engine, an then I'll tune it for power, I hope to see 0.6bar from this G60, motor has 9.2:1 compression ratio, stock G60 pulley but i'll go to a smaller one, maybe 72mm or 62mm.HidRo wrote:How does it run? How many horses? Stock, they were 205 or 210, but, not sure you created this one within stock spec.
Nice project ;)
this was it's first startup on ms2 v3 engine management:
http://www.youtube.com/watch?v=vb1JoDx4v8o
1990 Nissan Skyline 4 door r32 w/ ka24de(turbo soon now) engine, diypnp board set
4DR R32 KA24DET DIYPNP HOLSET HE341 18x10.5 / 18x12
https://www.facebook.com/HeatBloom
'87 Porsche 911 Carrera - turbocharged (1-bar) 3.4L - 431whp.
MS2 v3.57, Ford EDIS-6 ignition, 55lb. low-Z's, factory Bosch idle valve using FIdle, 36-1 wheel, GM IAT, factory cylinder head temp for CLT, E36 TPS.
'87 Porsche 911 turbocharged (Borg Warner S366/1.4 bar) 3.4L w/MS2 v3.57 running Ford EDIS-6
I have tuner studio and my wide band O2 up and running and well on to a good tune. The instal was ground up, and went very smoothly. I tuned the VR pots with a drill running the dizzy and everything was far easier that I feared it may be.
Here's what I have,
Lone Star Cobra replica
Ford Racing 427 based on Boss 351W block, Z heads
MS triggered with MDS dizzy, with centrifual advance only
MS will fudge the timing to add vacuum advance
MDS 6A box, wired with a connector and jumper so MS can directly fire the coil if MDS fails
60 lbs injectors
Edelbrok Super victor intake, rails and throttle body.
MS runs relay for the cooling fan also
Here's what I have,
60 lbs injectors
65 Cobra replica, 427W, MS2
71 Vette, 383 with shitty chinese 8 stack and no dizzy
Really bad photo of Shadow Dash MS in heads-up mode reflecting off my windshield at night. Pretty neat!
MS2 3.0 DIY kit from DIYAutotune.
Ford 351w (5.8 ) stroked to 393ci (6.4). 10.5:1 Compression. Comp camps XE282HR, Edelbrock Victor Jr heads 2.05/1.90, 42lb/hr (440cc) injectors.
Dual Widebands, Dual VE Tables, Closed loop EGO, closed loop IAC, Low & High speed fan control
Stock TFI Ignition
Runs great!
1988 Firebird Formula.
Engine is: 412" SBC, AFR 210 heads, singleplane 'hurricane' intake, 4bbl throttle body, NX276HR camshaft. Procharger P1SC, air/water intercooled.
ECM is Microsquirt module, with a racetronix D56 connector for 'plug and play' for an original 1227165 ECM replacement. MAF wires re-used for external MAP sensor. The module is inside a gutten OE delco ECM case, and I added an IAC stepper circuit to control a 4 wire GM/mopar IAC motor. Relay inside the case for OE fuel pump control (crash protection). The only thing I'm trying to work out is a circuit to log VSS..
http://members.cisdi.com/~anesthes/proj ... egasquirt/
I'm a software engineer, and MS is very appealing to me because of the native 'unix like' build environment, and the fact that I can make logical and functional changes in the firmware easily.
-- Joe
-- Joe
1991 BMW 318is
Garrett TA3017 turbo
2.5" exhaust
Home-made split-pulse manifold
Volvo 740 TIC intercooler
44 mm BOV, Tial 38mm WG
7.5 psi, soon to be 10 once I get the EBC circuitry installed.
MS2 extra, 2.1.0, sequential ignition, PWM idle, and soon to have an EBC.
260k miles, 50k on the turbo setup.
can't seem to find any underhood pics at the moment...
2.5" exhaust
Car: 1984 Opel Corsa A
Engine: C20NE (2.0 8v)
Mods:
Pistons and con-rods from C20LET with ARP bolts
Cilinderhead CNC machined combustion chambers
Home made exhaust manifold
Mitsubishi TD-04 13G
E85 fuel
1 bar boost
3 Inch downpipe, 2,5 Inch exhaust
470cc/min injectors from Opel Z20LEH
IC from toyota ? modified for my car
Forge dumpvalve twin piston
Innovate LC-1
MS2 V3.0, PWM CL Idle control, PWM boost controller, DIS-wastedspark, VR-input, Tacho-output, Clutch-switch
Bluetooth communication for Tunerstudio and MS-Droid
Plate/disc-type limeted slip differential
M&H 8,5/22-13 dragtyres
4 puck cinter clutchplate
Total weight of the car 690 kg
Best 1/4mile time 12,5 sec
Some old pics of the engine bay:
Mods:
E85 fuel
1 bar boost
Innovate LC-1
Opel Corsa A1 C20NE 320 pk 480 Nm 700 kg.
Turbo Garrett T04E35 @ 1,4 bar
Injectors 470cc/min (Opel Z20LEH) Fuel: Octane 102
MegaSquirt 2 V3.0 PWM CL Idle, PWM CL Boostcontroller, 4-Coil near plug, Launch/Flatshift, internal Bluetooth
60ft 1.77 sec. 1/4m 11.8 sec. @ 190 km/h
Nice specs,probably sound nice on full throttle.
Any pics of the engine bay?
I added some pictures.
Here is a video from dragracing in Drachten Netherlands:
http://www.youtube.com/watch?v=vLaykuag ... e=youtu.be
For more video's, look at my youtube channel.
http://www.youtube.com/user/freekcorsa?feature=watch
