set up using cam driven 36-1
Hello,
I'm looking at setting up my 1986 Citroen CX GTI turbo to run on megasquirt. sorry if I sound like a 16 year old newbe 'more a 47 year old' I would like to know if it is possible to trigger the unit from the camshaft using a 36-1 trigger wheel. I'd prefer not to take the engine out again... there's no crank pulley on these engines so it would mean having the flywheel drilled to a 60-2
currently the engine runs 2 sets of std injectors 'basically two injection sets' but I was looking to refine the engine management.
I have the trigger wheel all ready in place and really looking for re assuance it should work... and how to go about it please.
Re: set up using cam driven 36-1
Sure, this isn't too hard to do - what firmware are you running?
Well where did those two years go? I have 3.2.1 firmware and the cam trigger in place now.
This is still new to me and I have only connected it to the car to test if the signal from the trigger is working... there is a signal but in latest version of TS it only shows half the rpm the engine is running at.
I have the project set up to run cam driven toothed wheel 36-1 and wasted spark as my intention, was to run this through the MSD ignition already on the car.
Is there something else I'm missing please?
cheers
cheers
Could you post a copy of your MSQ? I'd like to check the settings first.
attached the file thanks, this is my first attempt
Sorry, looks like the file didn't attach correctly.
Just a thought, what speed did you set the trigger wheel in TS (Ignition Options Wheel/Decoder). As your wheel is driven from the cam, if you set it at "çrank" then it would show at 1/2 crank speed. Set it to Cam.
Triumph TR3A. MS3X, IBT, Fully Sequential Injection, Wasted spark, 60-2 crank wheel.
sorted the signals out, it all works fine now after downloading the latest firmware... this is a long project
