User Contributed Dashboards
Moderator: djandruczyk
I-w
Post by I-w »
lets see your dash gauge setup. post a screen shot of your dash gauges.
http://i139.photobucket.com/albums/q299 ... t/Dash.jpg
MS-1 3.0 ~ MapDaddy ~ Fan mod ~ Boost mod ~ 4G63 wiring issues Resolved!!! tuning Head Aches
Cuz
Post by Cuz »
djandruczyk
MS/Extra Guru
Post by djandruczyk »
Very slick! Please zip those gauge and dash XML files up and send them my way for inclusion into the next release of megatunix.
David J. Andruczyk
Cuz
Post by Cuz »
sure - email addy?
djandruczyk
MS/Extra Guru
Cuz wrote:sure - email addy?
look up at my post in the forum , the buttons are right there. for email and PM.
David J. Andruczyk
Cuz
Post by Cuz »
no worries. Do you mind having a look into the potential Boost Tables I posted in this forum?
djandruczyk
MS/Extra Guru
Cuz wrote:no worries. Do you mind having a look into the potential Boost Tables I posted in this forum?
yep I'll look at it.. thx for the notice..
David J. Andruczyk
Quan-Time
Re: User Contributed Dashboards
Post by Quan-Time »
http://www.tr1x.org/images/TR1X.zip - 13kb
As requested on faceytube. Its not my account, its a mates account. but i got the message :)
I have 2 files, day and night. hope they can be of use to you. Obviously the gauges have changed since that video.. It rev's properly now (i set the rev limiter ridiculously low in case anything bad happened)
Its sized for my 800x600 LCD, with a double size task bar (i use litestep for winXP because i couldnt get decent GPS software for linux :( )
join the (non official) Megasquirt IRC chat channel
##megasquirt @ irc.freenode.net
http://webchat.freenode.net/?channels=% ... irt&uio=d4 - click here to join live via java web-client, its instant !
http://www.msefi.com/viewtopic.php?f=92 ... de#p204682
Philip Lochner
Post by Philip Lochner »
Here's mine in full screen mode:
(The AFRerr gauge shows the difference between the wbo reading and the AFR that SHOULD be seen as per the AFR table) - this is my most important gauge )
Kind regards
Philip
Philip Lochner
...and here is my dash for the V12 Cobra I'm building....
Kind regards
Philip
superchargingmachine
Post by superchargingmachine »
I'm not sure this is the right place to post this question but it is related to dashboards so it seems close. When I click the button to load a dashboard and select any.xml dash MegaTunix closes. Is this normal when I'm not connected to the ECU?
I'm new to Megatunix but followed the setup and update instructions, which loaded all the latest ecu configs up to 3.2.4 so I thought I had things working properly.
djandruczyk
MS/Extra Guru
superchargingmachine wrote:I'm not sure this is the right place to post this question but it is related to dashboards so it seems close. When I click the button to load a dashboard and select any.xml dash MegaTunix closes. Is this normal when I'm not connected to the ECU?
What OS, and release (windows, linux, mac), what version of megatunix? i.e. 0.9.23 from SF.net or a git build, if git, which hash, and did you try the latest from git?
David J. Andruczyk
Linux Mint 13 XFCE, megatunix_0.9.23-lucid.deb from http://sourceforge.net/projects/megatunix, then did the git update,git clone git://github.com/djandruczyk/MegaTunix.git, etc
Everything seemed to run and complete but I have Megatunix in 2 folders automotive and accessories. When I launch MegaTunix I see the latest ECU's but when I select a dash MegaTunix closes.
I'm probably doing something I'm pretty new to Linux.
Completely uninstalled Megatunix, updated everything including the support files and installed from a fresh git compile. This time Megatunix only shows up is Accessories Menu. However, I'm still having the same problem on selecting, General, Choose a Dashboard File, click open(any dash) Megatunix closes.
As a final attempt, I removed the git compile. The just let The Debian Package Installer install the Sourceforge file. This puts Megatune back in both Accessories and Automotive but still the same problem on selecting, General, Choose a Dashboard File, click open(any dash) Megatunix closes.
This must be an issue with Mint or xfce.
djandruczyk
MS/Extra Guru
superchargingmachine wrote:Completely uninstalled Megatunix, updated everything including the support files and installed from a fresh git compile. This time Megatunix only shows up is Accessories Menu. However, I'm still having the same problem on selecting, General, Choose a Dashboard File Megatunix closes.
Since you installed the old binary from sourceforge and then installed on-top/inparallel from a git build, that's the problem (old style config files).
in your git Megatunix dir run the following to purge the parallel installs:
Code: Select all
sudo make uninstall
sudo apt-get purge megatunix
sudo rm -rf /usr/local/share/MegaTunix /usr/share/MegaTunix
sudo make install
sudo ldconfig
and it should work better.
David J. Andruczyk
I just followed your steps exactly and I'm still having the same issue. Thanks for the help. I may throw a different distribution on the machine and see if it works. If you want me to try something else with Mint let me know.
I decided to try again tonight with a clean install. I ran Megatunix from a terminal window. The gc-friendly is NOT set occurs after selecting the ECU and clicking the load button. Everything else happens after selecting General, choose a dashboard, open. Is this helpful in figuring out what's wrong? Thanks in advance.
choose_file
parent 0x8554678
on_top TRUE
filter *.*,All Files,*.xml,XML Files
filename (null)
default_filename (null)
default_extension (null)
absolute_path (null)
default_path Dashboards
external_path (null)
shortcut_folders Dashboards
project (null)
title Select Dashboard to Open
ACTION_OPEN before gtk_file_chooser_dialog_new
after gtk_file_chooser_dialog_new
should be using system path + Dashboards
initiating dialog to run
it returned
GLib (gthread-posix.c): Unexpected error from C library during 'pthread_setspecific': Invalid argument. Aborting.
Aborted
djandruczyk
MS/Extra Guru
superchargingmachine wrote:I decided to try again tonight with a clean install. I ran Megatunix from a terminal window. The gc-friendly is NOT set occurs after selecting the ECU and clicking the load button. Everything else happens after selecting General, choose a dashboard, open. Is this helpful in figuring out what's wrong? Thanks in advance.
choose_file
parent 0x8554678
on_top TRUE
filename (null)
project (null)
it returned
Aborted
That's a difficult one to trace. I'm nearly positive it's a GLIB bug, though the report I filed to the glib/gtk+ people over 6 months ago hasn't had any action taken on it by their developers.. Can you try the following below?
We need you to install the debug symbols for glib and gtk, so try and install the following packages from your repositories:
sudo apt-get install libglib2.0-0-dbg libgtk2.0-0-dbg libc6-dbg
in your git working copy, we need to build a version with debugging symbols turned on internally
make clean
./configure --enable-debug ; make ; sudo make install ; sudo ldconfig
gdb src/.libs/megatunix
run --g-fatal-warnings
run it as usual till it crashes
Then type "info threads" and it should list out whatever threads were running (copy and paste that here or to pastebin), basiclaly a thread number and then info about the thread numbers are important, you'll need them for the next step. For EACH thread in turn run "thread <threadnumber> from the list you just saw, and run "bt" (backtrace) and copy and paste the output from EACH thread to either here or pastebin, repeat this for EACH thread.
Thanks!
It would also help to know what version of libglib2 you have installed. (dpkg -l |grep libglib2.0)
David J. Andruczyk
I didnt have time to try this tonight. I should be able to tomorrow.
I'm not sure this is going to tell you a lot more.
paul@paul-HP-Compaq-nc6000-PD467AA-ABA ~/git/MegaTunix $ gdb src/.libs/megatunix
GNU gdb (Ubuntu/Linaro 7.4-2012.04-0ubuntu2.1) 7.4-2012.04
Copyright (C) 2012 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "i686-linux-gnu".
For bug reporting instructions, please see:
<http://bugs.launchpad.net/gdb-linaro/>...
Reading symbols from /home/paul/git/MegaTunix/src/.libs/megatunix...done.
(gdb) run --g-fatal-warnings
Starting program: /home/paul/git/MegaTunix/src/.libs/megatunix --g-fatal-warnings
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/i386-linux-gnu/libthread_db.so.1".
This is a debug release, Git hash: eb019a346db6d5b92b4682771e9a9cffa8e381c8
[New Thread 0xb2aacb40 (LWP 9777)]
choose_file
parent 0x8231678
on_top TRUE
filter (null)
filename (null)
default_filename MS2-Extra_V3.1.0_series-2013_01_15-1807.log
default_extension log
default_path Datalogs
shortcut_folders (null)
project default
title Choose a filename for datalog export
ACTION_SAVE calling gtk_file_chooser_dialog_new
[New Thread 0xb20ffb40 (LWP 9778)]
[New Thread 0xb18feb40 (LWP 9779)]
[Thread 0xb20ffb40 (LWP 9778) exited]
it returned
choose_file
parent 0x8231678
on_top TRUE
filter (null)
filename (null)
default_filename MS2-Extra_V3.1.0_series-2013_01_15-1807.ecu
default_extension ecu
default_path ECU_Backups
shortcut_folders MTX_ecu_snapshots
project default
title Save your ECU Settings to file
[New Thread 0xb20ffb40 (LWP 9780)]
[New Thread 0xb0effb40 (LWP 9781)]
[Thread 0xb0effb40 (LWP 9781) exited]
[Thread 0xb20ffb40 (LWP 9780) exited]
it returned
WARNING RAW value out of range for widget inj2_pwm_period_entry, clamped at 40.0 (40.0 <- 0 -> 100.0), updating ECU with valid value within limits!!
WARNING RAW value out of range for widget inj1_pwm_period_entry, clamped at 40.0 (40.0 <- 0 -> 100.0), updating ECU with valid value within limits!!
[Thread 0xb18feb40 (LWP 9779) exited]
choose_file
parent 0x8231678
on_top TRUE
filename (null)
project (null)
[New Thread 0xb18feb40 (LWP 9782)]
[New Thread 0xb20ffb40 (LWP 9783)]
[Thread 0xb20ffb40 (LWP 9783) exited]
it returned
Program received signal SIGABRT, Aborted.
0x00132416 in __kernel_vsyscall ()
(gdb) next
Single stepping until exit from function __kernel_vsyscall,
which has no line number information.
[Thread 0xb2aacb40 (LWP 9777) exited]
[Thread 0xb7fd68c0 (LWP 9774) exited]
Program terminated with signal SIGABRT, Aborted.
The program no longer exists.
