smoothing feature on 2.1.16
gimme a quick tutorial on how to use the table smoothing feature on 2.1.16 and how to set the factor...basic theory and operation stuff is what I really need .
Ricky-
MS3&MS3X v.3.0 PCB
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Re: smoothing feature on 2.1.16
How did you find this version? I looked at the tuner studio website and the latest is 2.1.1 and 2.0.8.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Yes, there are parts of that that are not finished yet and not fully tested or supported. That is why it is in the alpha folder. It was needed for testing with the latest alpha MS2Extra firmware though.
I do expect to have it ready for beta this week.
Anyway to the point of the OP...nismoautoxr wrote:gimme a quick tutorial on how to use the table smoothing feature on 2.1.16 and how to set the factor...basic theory and operation stuff is what I really need .
That function is in the beta already. It will also be in the next release of MLV.
The smoothing factor controls how much weighting is given to the surrounding table cells vs each individual cell.
The value should be between 0 & 1.0 with
0 = 0% of the surrounding cell values are considered, thus no smoothing will be done.
1.0 = 100%, so each cell value itself is not considered, the output value is driven entirely by the values of the surrounding cells, thus this will smooth the most.
The default value is 0.7, to change the smoothing factor right click on the smoothing button.
so to use the smoothing feature then one would higlight the area that one wants smoothed or just the particular cell in question...say like you got one large or small cell inthe middle of som very differant ones....how does it work?
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Yes, select 1 cell, whole table, or any set of cells. The selected cells will be smoothed, the rest left alone.
Try it, it is best of you open a 3D table next to it so you can see the smoothing.
Also as always if you hold the mouse over any changed cell it will tell you the original value in the tooltip.
gotcha thanks.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
