MS2 development/coding for dummies
Re: MS2 development/coding for dummies
Hey guys I'm working for my Fsae team and i want to implement a traction control so i want to be able to change the advance on the run and cut some spark events if spark retard is not enough. And i was thinking if it is possible to do something wrong that could make ms2 unprogramable?
What you want to do is possible, but on an ms2 the big issue will be available inputs to detect when you've lost traction.elsp1991 wrote:Hey guys I'm working for my Fsae team and i want to implement a traction control so i want to be able to change the advance on the run and cut some spark events if spark retard is not enough.
It is, but you can just trip the boot jumper and reset the ms2 back to a state that will allow serial programming again.And i was thinking if it is possible to do something wrong that could make ms2 unprogramable?
I've had to rely on that a few times when I crash the CPU or do some code loops that stop serial interrupts from being active.
G
Mazda MX5 + MS3 Pro
Ok this is the thing i want to do with MS2. An avr will produce a analog output. And i have some question
1. The thing is that i dont know the internal variable of adc7, do you know where i can find this info.
2. should i put this tile in several places or just before the end of the main loop? cause i notice that ms2 do launch in several lines??!!
3. user_value_1 = my spark retard
user_value_2 = adc prescaler in order to convert 0-1024 range to 0-50
(????adc7???) = adc7 input signal
Code: Select all
//my code
user_value_1 = user_value_2*(????adc7???);
if (user_value_1 >= 20) //spark retard is not enough cut some events
user_value_1 = 20;
spk_cutx = 4;
spk_cuty = 7;
outpc.status2 |= status2_spkcut; //do spark cut with above x,y
else if (user_value_1 <= 20) //spark retard is enough dont need to cut events
outpc.status2 &= ~status2_spkcut; //disable spark cut
else if (user_value_1 <=0)
user_value_1 = 0;
lsum += user_value_1;
//end of my code
outpc.adv_deg = (int)lsum; // Report advance before we fudge it
take a look in megasquirt 1 and see how traction control/anti-rev is done, it is a crude implementation but it does it's job, too bad it didn't make it in ms2-extra code, it would be very usefull even if it was just rpm based.
Example on how to search for stuff:elsp1991 wrote:1. The thing is that i dont know the internal variable of adc7, do you know where i can find this info.
Code: Select all
[jsm@jsm2 ms2extra]$ grep -i adc7 *.c
ms2_extra_main.c: retard based on ADC7 sensor.
ms2_extra_misc.c: outpc.adc7 = ATD0DR7;
ms2_extra_misc.c: tmpadc = outpc.adc7;
ms2_extra_misc.c: txbuf.adc7 = outpc.adc7;
i use this editor for my small changes in the code, "find in files" and nice color coding makes life a little more easy.
http://www.editplus.com/
Is that what one would do in Linux? I'd like to compile some code to test CANBus in BMW setup (apparently different ID's and multipliers).jsmcortina wrote:If it didn't give an error message then it worked.Martin Young wrote:Anyway, I try to follow the instruction but having entered the tar command with the path to get to the tools.tar.gz file, nothing appears to happen. I don't know if anything ought to happen, but nothing does.
If you prefer to see tons of output, use:
cd /
tar xvfz <path>/tools.tar.gz
To see if it extracted:
ls -l /usr/bin/m9s*
When I tried above I got a bunch of errors, the last few being:
tar: usr/m68hc11-elf/lib/m9s12x/libm.a: Cannot open: No such file or directory
usr/m68hc11-elf/lib/m9s12x/libbcc.a
tar: usr/m68hc11-elf/lib/m9s12x/libbcc.a: Cannot open: No such file or directory
usr/m68hc11-elf/lib/libbcc.a
tar: usr/m68hc11-elf/lib/libbcc.a: Cannot open: No such file or directory
tar: Exiting with failure status due to previous errors
I'm really pretty much an idiot in Linux.
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
PF Tuning
Not exactly sure what's wrong. A couple of things:
You should then see a list of the various files and directories as they are created.
All that said, the error messages don't really look like you've got a problem with either of these things. Just can't think of anything else to suggest.
Have fun,
Rob.
- you must be root to write to these directories. (either use sudo before the tar command or do "sudo su -" to log in as root full time).
- if you have put the tools.tar.gz file in /tmp, the commands you want to type are:
Code: Select all
cd /
tar xvfz /tmp/tools.tar.gz
Have fun,
Rob.
I'll try that.
Thanks!
Thanks!
Peter Florance
PF Tuning
PF Tuning
I'd also suggest that you use the current build tools release and see the instructions it includes.
http://www.msextra.com/tools
James,
i downloaded the 2012 version of the linux toolchain, extracted and installed it according to README.
Now my problem is, the makefiles point to m9s12x-elf-gcc but there is no such files included in the tar archive. Only versions for m9s11.
What to do in this case? use 2010 version or rename the gcc files?
thanks, Stefan
thanks, Stefan
What code are you trying to compile?
The most likely fix is to edit the appropriate Makefile to replacewith
Code: Select all
PROGPREF=$(BINDIR)m9s12x-elf-
Code: Select all
PROGPREF=$(BINDIR)m68hc11-elf-
i was trying the 3.2.5 release.
i do see now that its fixed in latest beta.
thx
thx
Hi all:
I've been trying to get a build to succeed, but always get errors. Does any of this mean anything to you. The folders are there and I have edited the make files. Thanks in advance for taking a look.
cory@satellite /cygdrive/c/cygwin/ms2extra_3.2.5_release/ms2extra
$ make release
rm -f -rf release megasquirt-ii.ini.ms2extra megasquirt-ii.ini.us2extra *~
make --makefile Makefile.ms2 clean
which: no m68hc11-elf-gcc in (/usr/local/bin:/usr/bin:/cygdrive/c/Program Files/Common Files/Microsoft Shared/Windows Live:/cygdrive/c/Program Files (x86)/Common Files/Microsoft Shared/Windows Live:/cygdrive/c/windows/system32:/cygdrive/c/windows:/cygdrive/c/windows/System32/Wbem:/cygdrive/c/windows/System32/WindowsPowerShell/v1.0:/cygdrive/c/Program Files (x86)/Windows Live/Shared:/cygdrive/c/Program Files/Intel/WiFi/bin:/cygdrive/c/Program Files/Common Files/Intel/WirelessCommon:/usr/lib/lapack)
ls: cannot access /usr/bin/m68hc11-elf-gcc: No such file or directory
ls: cannot access c:cygwin/usr/bin/m68hc11-elf-gcc: No such file or directory
make[1]: Entering directory `/cygdrive/c/cygwin/ms2extra_3.2.5_release/ms2extra'
rm -f -f ms2_extra.elf
rm -f -f ms2_extra.s19
rm -f -f ms2_extra.dmp
rm -f -f ms2_extra.map
rm -f -f ms2_extra_main.o ms2_extra_can.o ms2_extra_can_isr.o ms2_extra_ego.o ms2_extra_ign.o ms2_extra_ign_wheel.o ms2_extra_misc.o premain.o ms2_extra_init.o sigs.o ms2_extra_ign_in.o ms2_extra_inj.o ms2_extra_idle.o ms2_extra_user.o msii_flash_gcc.o ms2_sermon.o ms2_conferr.o ms2_extra_burner.o ms2_extra_burnfactor.o isr_inj.o isr_sci.o isr_rtc.o ms2_extra_asm.o isr_timerovf.o isr_ign.o crc32.o interp.o
rm -f -f us_opt_c.h
rm -f -f us_opt_asm.inc
make[1]: Leaving directory `/cygdrive/c/cygwin/ms2extra_3.2.5_release/ms2extra'
make --makefile Makefile.us clean
cygwin warning:
MS-DOS style path detected: c:/usr/bin/m68hc11-elf-gcc
Preferred POSIX equivalent is: /cygdrive/c/usr/bin/m68hc11-elf-gcc
CYGWIN environment variable option "nodosfilewarning" turns off this warning.
Consult the user's guide for more details about POSIX paths:
http://cygwin.com/cygwin-ug-net/using.h ... -pathnames
ls: cannot access c:/usr/bin/m68hc11-elf-gcc: No such file or directory
rm -f -f ms2_extra_us.elf
rm -f -f ms2_extra_us.s19
rm -f -f ms2_extra_us.dmp
rm -f -f ms2_extra_us.map
rm -f -f us_opt_c.h
make -C bootstrap_src clean
make[1]: Entering directory `/cygdrive/c/cygwin/ms2extra_3.2.5_release/ms2extra/bootstrap_src'
rm -f -f bootstrap.elf
rm -f -f bootstrap.s19
rm -f -f bootstrap.dmp
rm -f -f bootstrap.map
rm -f -f ms2_extra_main.o premain.o sigs.o msii_flash_gcc.o ms2_sermon.o isr_sci.o ms2_extra_asm.o
make[1]: Leaving directory `/cygdrive/c/cygwin/ms2extra_3.2.5_release/ms2extra/bootstrap_src'
rm -f -f ms2_extra_ign.o ms2_extra_ign_in.o ms2_extra_init.o ms2_extra_misc.o isr_ign.o isr_inj.o isr_rtc.o ms2_extra_main.o ms2_extra_idle.o ms2_extra_inj.o sigs.o
echo '// setup for Megasquirt' > us_opt_c.h
echo '; setup for Megasquirt' > us_opt_asm.inc
m68hc11-elf-gcc -g -Wall -Werror -O -fomit-frame-pointer -m68hcs12 -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -DGCC_BUILD -c ms2_extra_main.c
make[1]: m68hc11-elf-gcc: Command not found
Makefile.ms2:47: recipe for target `ms2_extra_main.o' failed
make[1]: *** [ms2_extra_main.o] Error 127
Makefile:16: recipe for target `megasquirt' failed
make: *** [megasquirt] Error 2
$ make release
rm -f -f us_opt_c.h
cygwin warning:
rm -f -f us_opt_c.h
Before trying to make a release, I'd suggest building a single target.
Did you check through the error messages?
Looks like you do not have the build tools installed or they aren't installed in the correct place.
James:
Thanks! I'll give that a try. I'm new to tar and gz so i'm not sure I did it right either. I'll double check and post results.
Thanks!
Cory
Thanks!
Cory
James:
Still no success. I have a C:/cgywin folder and inside are several folders including the ms firmware and the usr files. When I unzip/untar the tools into the cygwin root folder I get a folder named tools.tar. The tools.tar folder also has a usr file inside. Can you help me understand how,the file structure has to look to make this work?
In the usr/bin folder there are two m68hc11-elf-gcc exe files. One has a version number behind it and is abt 180kb while the plain one is 0kb not sure this is significant.
I appreciate your help.
Cory
Cory
Did you follow the instructions in the README file?
You will expect to see the files that the Makefile is looking for
e.g. as viewed by Cygwin, /usr/bin/m68hc11-elf-gcc
James:
I Googled how the cygwin tar function works and was able to untar the tools.tar.gz into the cygwin folder. I now have the m68hc11-elf-gcc file with a 276kb size. I still get the file or folder do not exist errors even though I have re-booted and also ran cygwin as administrator. I am running Win7 if that matters. I have edited line 13 of the make.us file from: PROGPREF=$ (BINDIR)/m9s12x-elf- to: PROGPREF=$ (BINDIR)/m68hc11-elf-
I notice that on line 11 there are 4 references to "usr/bin/m9s12x-elf-gcc do these need to be edited also?
Sorry to be a pain, I did read the README, I have never used linux in my life. I've only ever programmed PIC, Arduino and Picaxe controllers, so this is a significant jump in technology for me.
Cory
Cory
Ok, so after hopefully learning how to install the build tools I still get errors. Being unfamiliar with Unix/Linux, I'm not sure what all the errors mean or how to go about fixing them so here is a screen dump of the errors i am getting. If you have any ideas on how to get this going I would be very grateful.
cory@satellite /cygdrive/c/cygwin/ms2extra_3.2.1_release/ms2extra_3.2.1_release/ms2extra
$ make us
which: no m9s12x-elf-gcc in (/usr/local/bin:/usr/bin:/cygdrive/c/Program Files/Common Files/Microsoft Shared/Windows Live:/cygdrive/c/Program Files (x86)/Common Files/Microsoft Shared/Windows Live:/cygdrive/c/windows/system32:/cygdrive/c/windows:/cygdrive/c/windows/System32/Wbem:/cygdrive/c/windows/System32/WindowsPowerShell/v1.0:/cygdrive/c/Program Files (x86)/Windows Live/Shared:/cygdrive/c/Program Files/Intel/WiFi/bin:/cygdrive/c/Program Files/Common Files/Intel/WirelessCommon:/usr/lib/lapack)
ls: cannot access /usr/bin/m9s12x-elf-gcc: No such file or directory
cygwin warning:
MS-DOS style path detected: c:/usr/bin/m9s12x-elf-gcc
Preferred POSIX equivalent is: /cygdrive/c/usr/bin/m9s12x-elf-gcc
ls: cannot access c:/usr/bin/m9s12x-elf-gcc: No such file or directory
make[1]: Entering directory `/cygdrive/c/cygwin/ms2extra_3.2.1_release/ms2extra_3.2.1_release/ms2extra'
echo '#define MICROSQUIRT' > us_opt_c.h
echo '.set MICROSQUIRT, 1' > us_opt_asm.inc
/m68hc11-elf-gcc -g -Wall -Werror -O -fomit-frame-pointer -m68hcs12 -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -DGCC_BUILD -c ms2_extra_main.c
make[1]: /m68hc11-elf-gcc: Command not found
Makefile.us:48: recipe for target `ms2_extra_main.o' failed
make[1]: Leaving directory `/cygdrive/c/cygwin/ms2extra_3.2.1_release/ms2extra_3.2.1_release/ms2extra'
Makefile:18: recipe for target `microsquirt' failed
make: *** [microsquirt] Error 2
I have also attached my make file to make sure I have edited it correctly and in the right places.
#* Makefile for MSII
#* COPYRIGHT: Philip L Johnson 2004
#* This header must appear on all derivatives of this file.
# Extended for MS2/Extra by Ken Culver and James Murray 2006
# $Id: Makefile.us,v 1.11 2011-11-12 17:26:06 jsmcortina Exp $
BINDIR:=$(shell ls /usr/bin/m9s12x-elf-gcc c:/usr/bin/m9s12x-elf-gcc `which m9s12x-elf-gcc` | head -1 | sed -e's,m9s12x-elf-gcc,,g' 2> /dev/null)
PROGPREF=$(BINDIR)/m68hc11-elf-
CC = $(PROGPREF)gcc
OBJCOPY = $(PROGPREF)objcopy
OBJDUMP = $(PROGPREF)objdump
NM = $(PROGPREF)nm
CFLAGS = -g -Wall -Werror -O -fomit-frame-pointer -m68hcs12 -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -DGCC_BUILD
LDFLAGS = -Wl,-defsym,vectors_addr=0xff80,-m,m68hc12elfb,-T,m68hc12elfb.x
CSRCS=ms2_extra_main.c ms2_extra_can.c ms2_extra_can_isr.c ms2_extra_ego.c ms2_extra_ign.c ms2_extra_ign_wheel.c\
ms2_extra_misc.c \
premain.c ms2_extra_init.c sigs.c ms2_extra_ign_in.c ms2_extra_inj.c \
ms2_extra_idle.c ms2_extra_user.c
ASRCS=msii_flash_gcc.s ms2_sermon.s ms2_conferr.s ms2_extra_burner.s \
ms2_extra_burnfactor.s isr_inj.s isr_sci.s isr_rtc.s ms2_extra_asm.s \
isr_timerovf.s isr_ign.s crc32.s interp.s
OBJS=$(CSRCS:.c=.o)
AOBJS= $(ASRCS:.s=.o)
all: setmicrosquirt ms2_extra_us.dmp ms2_extra_us.elf ms2_extra_us.s19
#in order to safely build both targets, must remove existing object code
setmicrosquirt:
# touch ms2_extra.h
$(AOBJS): %.o: %.s
$(CC) $(CFLAGS) -c $<
$(OBJS): %.o: %.c cltfactor.inc egofactor.inc matfactor.inc hcs12def.h flash.h ms2_extra.h
ms2_extra_us.elf: $(OBJS) $(AOBJS)
$(CC) $(CFLAGS) $(LDFLAGS) -o ms2_extra_us.elf $(OBJS) $(AOBJS)
ms2_extra_us.s19: ms2_extra_us.elf
$(OBJCOPY) --output-target=srec \
--only-section=.text3 \
--only-section=.rodata \
--only-section=.vectors \
--only-section=.eeprom \
--only-section=.lookup --change-section-lma .lookup=0x3Ca400 \
--only-section=.text3c --change-section-lma .text3c=0x3C8000 \
--only-section=.text3d --change-section-lma .text3d=0x3D8000 \
--only-section=.text3b --change-section-lma .text3b=0x3B8000 \
--only-section=.text3a --change-section-lma .text3a=0x3A8000 \
--only-section=.text39 --change-section-lma .text39=0x398000 \
--only-section=.text38 --change-section-lma .text38=0x388000 \
--only-section=.lookup \
--only-section=.text \
$(NM) ms2_extra_us.elf | sort > ms2_extra_us.map
ms2_extra_us.dmp: ms2_extra_us.elf
$(OBJDUMP) -Ssdp ms2_extra_us.elf > ms2_extra_us.dmp
PHONY: clean
clean:
$(RM) -f ms2_extra_us.elf
$(RM) -f ms2_extra_us.s19
$(RM) -f ms2_extra_us.dmp
$(RM) -f ms2_extra_us.map
$(RM) -f $(OBJS) $(AOBJS)
$(RM) -f us_opt_c.h
$(RM) -f us_opt_asm.inc
Sorry for the SUPER long post, but the board wont accept a .us or .docx format and everything else I tried to save it as destroyed the formatting so it wouldn't work otherwise.
Thanks again
Cory
$ make us
cygwin warning:
CC = $(PROGPREF)gcc
NM = $(PROGPREF)nm
ms2_extra_misc.c \
OBJS=$(CSRCS:.c=.o)
setmicrosquirt:
# touch ms2_extra.h
$(AOBJS): %.o: %.s
PHONY: clean
clean:
$(RM) -f us_opt_c.h
Thanks again
Cory
