With the recent success from the generic decoder wheel mode,has anyone successfully do away with the edis4 module?
Can MsnS decoder mode be used to fire 4 cyl wasted spark from the 36-1 wheel? Because i wanted to remove the edis module completely.
speedy
Wasted spark mode from 36-1 wheel
I have run a 36-1 setup using the LM1815 circuit and two HEI4 modules on the test bench and it worked ok. I have not tried it on an engine.
Unless you NEED spark cut I would advise people to stay with the EDIS module as it is a proven robust solution.
Southern hemisphere guys may find the wheel decoder an interesting solution as I believe EDIS is not easily available there.
For wheel decoder stick with 021u code for the moment.
