GM DIS install
jeep45238
GM DIS install
Post by jeep45238 »
Well, apparently the HEI and DIS of GM uses the same code, so it should be able to operate both peices of hardware.
Now, this install would be on a turbocharged 1.9L Saturn I4 engine, OBD1.
Looking at the picture, I would think that the pick-up coil would be the crank sensor in my application, which has 2 wires, but unfortuantely, it doesn't say a positive or a negative in the picture.
Would I absolutely have to run the HEI modual to fire the coil packs? Since my application uses 2 coils, would I have to splice into the coils directly, or is there some way to use my original ignition modual to get the fire starting?
The way the crank sensor in a saturn works is there's a notch in the crank that triggers this magnetic sensor. Same idea as mounting a magnet and reciever on a crank pulley or flywheel.
Any suggestions on rigging this up for a GM DIS install, anybody?
Thanks!
Mike
Turbo Saturn DOHC Cam re-grinds group buy,
$370, dyno'd to over 300 fwhp!!
http://www.turbosaturns.net/forum/viewtopic.php?t=10408
jeep45238
Post by jeep45238 »
Any ideas?
Will Marsh
Re: GM DIS install
Post by Will Marsh »
jeep45238 wrote:Looking at the picture, I would think that the pick-up coil would be the crank sensor in my application, which has 2 wires, but unfortuantely, it doesn't say a positive or a negative in the picture.
If you look at the module in the pic you might note that one of the pickup terminals is marked "P" and the other is marked "N". :wink:
Beyond that I have no idea.
HTH,
Will Marsh
'72 IH 1010 Travelall, Ms'd V392
jeep45238
Post by jeep45238 »
Wow....man, the flu is knocking me out.
Danka danka danka.
