Seattle Washington - Tuning / Install / Consulting
I can do consulting, installs, tuning, remote tuning, harness building, pretty much anything MS.
located in Monroe, Washington and can travel.
Complete MS Repair / upgrade services also available.
Local References:
SEATTLEJESTER - MS2 v3.57 - 240z with a 7mgte
Ollie8974 - MS3X v3.57 - 79 Pontiac Trans Am
Chris S. - DIYPNP - Corolla GTS (ae86) with a 1.6L 16v 4age
Artimus Prime - MS2 v3 - Turbo VW Manx
subarvair - MS3X v3.57 - Corvair W/ Subaru EG33
turbobaja - MS3-PRO - 73 Baja 2110cc Turbo
Local References:
Re: Seattle Washington
Just getting ready for first start. Depending how things go might need some advice.
Cheers,
Greg Moore
Cheers,
Greg Moore
Greg
1974 Jensen Healey
Lotus 906/907 engine (907 block, 906 crank, dry-sump, cylinder head, pistons, Cosworth BDA valves, springs, cam followers)
1974 Jensen Healey
Hi Greg, sounds good.
Looks like you have a great project in the works.
PM Sent
PM Sent
Glad to see someone is around,
I may be knocking on your door real soon.
Brian
Brian
Hey Brian, great! What are you building?seattlejester wrote:Glad to see someone is around,
Brian
Hi Mario,
It is a 240z with a 7mgte.
I have gotten it to run and drive, but it won't rev past 4500rpm or so. I'm running out of things I can check. May have to try and put put it to your place if I can't make any progress.
Oh that's perfect. I don't have much space for another car right now But if you can drive it that makes thing easy. Just let me know!
Where are you located?
I am in Bellevue.
Unsure if it is a simple fix and I drive it there and drive it back kind of deal, or if it would be a leave it at the shop kind of deal. Hopefully the community can give me a few pointers, if I can't figure it out on my end, I sure am glad there is someone who is familiar with these systems when I throw in the towel.
Sounds good. just let me know before you get to frustrated I can just come out to Bellevue as well, not a problem.
Excellent,
I think it may be wise to move this over to PM's so I don't clutter your thread anymore.
Cheers!
Cheers!
Happy to find a MS tuner close by. I am located in Lynnwood.
We need to talk.
I too will go over to PM.
Thanks, Ollie
We need to talk.
Thanks, Ollie
Hey local Seattle-ish area people. I just got my MS3X engine started and am working on the tune. I'm looking for a bit of help tuning the cruise portion of my map while the engine breaks in.
Specs on the engine/MS3
5.9 Dodge Magnum
10:1 Compression, zero deck, .039 quench
Hughes HER0814ALN-10 cam, 208 duration, .512 lift, 110 lsa
shorty headers
LS2 coils x 8
M1 intake
52 mm throttle body
running full sequential fuel and spark. Let me know if anyone is willing to look at my .msq or discuss tuning theory over a beer. I'll buy.
Connor
5.9 Dodge Magnum
shorty headers
LS2 coils x 8
M1 intake
52 mm throttle body
Connor
Hi Connor,
Where are you located? If you want to come out to Monroe I'de love to talk MS
Re: Seattle Washington - Tuning / Install
Hey Mario. We should get a PNW meet somewhere. I know there's lots of us here, be cool to get together and talk megasquirt for sure
I live in Lynnwood. Monroe isn't too far away. We pass through there all the time on our way to Stevens Pass. Once this quarter settles in I'll make some time to drive the truck out there. I'm reading as much tuning theory as I can but there is a lot of information out there. the truck pulls good down low but the high rpm seems to fall off. I think I need more advance and I know I need bigger injectors.
Connor
Connor
That would be killer. It' been at least 5 years since a West Coast MegaMeet. But I think we could put together a more casual GTG.nathaninwa wrote:Hey Mario. We should get a PNW meet somewhere. I know there's lots of us here, be cool to get together and talk megasquirt for sure
Your duty cycle will tell you the injector story. Have you taken a loot at plugs after a good pull? If you ever think about dyno time I have a connection with Dyno Authority in Redmond.dakotaprerunner wrote:I live in Lynnwood. Monroe isn't too far away. We pass through there all the time on our way to Stevens Pass. Once this quarter settles in I'll make some time to drive the truck out there. I'm reading as much tuning theory as I can but there is a lot of information out there. the truck pulls good down low but the high rpm seems to fall off. I think I need more advance and I know I need bigger injectors.
I would be interested in get together as well.
Mario,
Duty cycle at WOT is 100% or greater and I measured the factory injectors at 242 cc/min. Have not pulled the plugs yet but I am going to do that after class tomorrow. One of my problems right now is my laptop is dead... I ordered a new one that should be here this week. I have Tunerstudio and MegaLog Viewer.
Connor
Mario,
Connor
I'm interested in a GTG also....
I wouldn't be able to take my buggy if the weather is crappy though...
It sure would be cool to see all the other setups in the area.
Re: Seattle Washington - Tuning / Install / Consulting
Anyone doing dyno turning for MS in the South King County / Tacoma area?
I haven't worked with any shops down that way, I usually use Carb Conn in Kirkland
